7303 Discussions
zfeast_hrci initialization shows strange behaviour
Christian_M_3
Hi all,
i am working my way through the example zexample_sparse_rci_c.c. I have it working now for my matrix, BUT found a strange behaviour for the input arrays Aq and Sq:
when declaring them like this:
MKL_Complex16  Aq[M0SQUARE]; (where MOSquare is an integer) everything works fine.
When declaring them like
MKL_Complex16 *Sq = new MKL_Complex16[M0SQUARE];
the first call to zfeast_hrci  fails with:
Thread #1 [feastTrial] 5489 [core: 2] (Suspended : Signal : SIGSEGV:Segmentation fault)
    mkl_feast_zfeast_hrci() at 0x7ffff617fedf
    zfeast_hrci_() at 0x7ffff7959141
    testAddition() at feastTrial.cpp:251 0x4047da
    0x0
. Strangely enough: when declaring workc and work with new .... no problems occur.
What am I missing here?
I want to have all memory on the heap in order to cope with LARGE matrices.
Ying_H_Intel
Hi Christian,
how do you declare the M0SQUARE?  Could you please provide us one test case?
I use the zexample_sparse_rci_c.c -> covert to CPP file.  with MKL_Complex16 *Sq = new MKL_Complex16[M0SQUARE];
It seems work fine.  I attached the cpp code for your reference.
Ying
Christian_M_3
Hello Ying,
MKL_INT       M0;
    if (dimension < 500)
        M0=dimension*0.5;
    else
        M0=dimension*0.1;
    int workSize = M0*dimension;
    MKL_INT M0StartValue = M0;
    MKL_INT M0SQUARE = M0*M0;
The values in my testcase are dimension=495, M0= 247 and so on.
One more thing I forgot to mention:
I use the gcc compiler, (4.8.4) on ubuntu linux.
Thanks for your help.
Christian
Christian_M_3
OK. It seems to me that cannot mix the declaration/allocation types with my version of gcc
(i.e. having
and
in the program
replacing all declarations with new [] helped.
 BUT now comes the next problem:
When trying to delete those arrays, the program crashes when trying to delete [] Sq; claiming the pointer would be invalid.
Any ideas why this happens? All other pointers can be deleted properly.
Ying_H_Intel
Hi Christian,
is there any special compiler option in your CPP code?   or is there any special code (for example, delete [] Sq in while loop)  in your CPP code?
I add
 printf( "Max of (conjugate transposed of X)*X-I %.15e \n", smax);
    delete [] Sq;
    return 0;
 tried the command;
 $source /opt/intel/compilers_and_libraries_2016.2.181/linux/mkl/bin/mklvars.sh intel64
 $g++ zexample_sparse_rci_c.cpp  -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lm
hu5@ivb01-ub:~/Merry$ ./a.out
    FEAST ZFEAST_HRCI EXAMPLE PROGRAM
Sparse matrix size  10
 Search interval [ 2.000000000000000e+00, 1.200000000000000e+01 ]
Intel MKL Extended Eigensolvers: complex double precision driver
Intel MKL Extended Eigensolvers: List of input parameters fpm(1:64)-- if different from default
Intel MKL Extended Eigensolvers: fpm(1)=1
Intel MKL Extended Eigensolvers: fpm(6)=1
It run fines.
yhu5@ivb01-ub:~/Merry$ g++ --version
g++ (Ubuntu/Linaro 4.8.1-10ubuntu9) 4.8.1.
Could you provide us a test main cpp file, so we can debug at our sides?
Ying
