7299 Discussions
How to do a 2d Fourier tranformation stored in column-major?
Ye_C_
I have read the MKL manual but I can hardly understand the explanation below:
MKL_LONG dims[] = { nd, …, n2, n1 };
DftiCreateDescriptor( &hand, precision, domain, d, dims );
// The above call assumes data declaration:  type X[nd]…[n2][n1]
// Default strides are { 0, nd*…*n2*n1, …,  n2*n1, n1, 1 }
It is obvious that there are nd+2 elements in the strides configurations, i.e., for 2d data, the default strides are {0, n2*n1, n1, 1},
the first element 0 is the default value for s0, except which there are still 3 elements.
I don't know how to under the configuration of strides.
By now, I have a 2d data stored in column-major, how to set the strides for the column-major storage?
Ying_H_Intel
Hi
It seems bring some confusion here.  I will check internally.
but the key is  how the x(k1, K2) are gotten.
The memory address of the
element X(k1, k2 , ..., kd) is expressed by the formula
address of X(k1, k2, ..., kd) = address of X(0, 0, ..., 0) + offset
= address of X(0, 0, ..., 0) + s0 + k1*s1 + k2*s2 + ...+ kd*sd,
where s0 is the displacement and s1, ..., sd are generalized strides.
So for 2d data,   for   column-major storage,  X(k1,k2)= x(0,0)+K1*1 + K2* row-number, the strides looks be {0, 1, row-number}
You may refer to some sample coded under MKL install directory. for example, mkl_example\examples_core_c\dftc\source\config_placement.c to understand the stride and the compress format if real.
Ying
Ye_C_
Thanks!
I have guessed the solution.
Grateful for your clear answer!
Yours,
Ying H (Intel) wrote:
Hi
Ying
