7294 Discussions
zheevd cannot converge on p4 in some cases
dgorlov
hello.
I found a strange behaviour of zheevd function on pentium 4 processor
on some real matrices or order 64
on core2duo processor these program works correct
test program:
it fails with message "bug - process not converged."... only on p4 with sse3
program was built using Visual Studio 2008 and MKL 10.1.1.022 with static link or dymamic link
when i use dynamic link, there was no problem when i remove mkl_p4p.dll ...
#define _CRT_SECURE_NO_WARNINGS
#include
#include
#include
#include
#include "mkl_lapack.h"
#include "mkl_service.h"
#define INPUT_FROM_FILE
#define MAX 1000
typedef struct {
int work_size;
int rwork_size;
int iwork_size;
MKL_Complex16* work;
double* rwork;
int* iwork;
} EV;
void init(int n, EV &data)
int info;
MKL_Complex16 work_size_d = {0, 0};
double rwork_size_d = 0;
int iwork_size_d = 0;
int const_m1 = -1;
zheevd("V", "L", &n, 0, &n, 0, &work_size_d, &const_m1, &rwork_size_d, &const_m1, &iwork_size_d, &const_m1, &info);
_ASSERT(!info);
data.work_size = (int)(floor(work_size_d.real + 0.5));
data.rwork_size = (int)(floor(rwork_size_d + 0.5));
data.iwork_size = iwork_size_d;
data.work = (MKL_Complex16*)malloc(data.work_size * sizeof(MKL_Complex16));
data.rwork = (double*)malloc(data.rwork_size * sizeof(double));
data.iwork = (int*)malloc(data.iwork_size * sizeof(int));
int ev(MKL_Complex16 *matrix, double *eigenvals, int n, EV &workBuffer)
int info;
zheevd("V", "L", &n, matrix, &n, eigenvals, workBuffer.work, &workBuffer.work_size, workBuffer.rwork, &workBuffer.rwork_size, workBuffer.iwork, &workBuffer.iwork_size, &info);
if(info != 0)
printf("bug - process not converged. info = %d\n", info);
return info;
MKL_Complex16 inp_matrix[MAX * MAX];
MKL_Complex16 eigenvectors[MAX * MAX];
double eigenvals[MAX];
int main(void) {
int n;
FILE *inf;
EV e1;
memset(&e1, 0, sizeof(EV));
inf = fopen("bug_matrix_30.txt", "rt");
if(inf == 0)
printf("cannot open file\n");
return 1;
fscanf(inf, "%d", &n);
init(n, e1);
for(int i = 0; i < n; ++i)
for(int j = 0; j < n; ++j)
fscanf(inf, "%lf", &inp_matrix[i * n + j].real);
inp_matrix[i * n + j].imag = 0;
if(fabs(inp_matrix[i * n + j].real - inp_matrix[j * n + i].real) > 1e-10)
printf("bug = matrix not symmetric\n");
return 1;
memcpy(eigenvectors, inp_matrix, sizeof(inp_matrix));
int r = ev(eigenvectors, eigenvals, n, e1);
if
printf("bug - cannot converge. info = %d\n", r);
return 1;
fclose(inf);
printf("ok");
return 0;
dgorlov
there is sample program and input file
files attached
Gennady_F_Intel
I am afraid, I didn't understand how do link your code.
Which libraries were used for linking your application?
--Gennady
dgorlov
--Gennady
I link to(when i use static link to mkl)
mkl_core.lib
mkl_intel_c.lib
mkl_intel_thread.lib
libguide.lib
when i use dynamic link i use
mkl_core_dll.lib
mkl_intel_c_dll.lib
mkl_intel_thread_dll.lib
Gennady_F_Intel
Do you have the similar output? see below:
"test.exe bug_matrix_30.txt
bug - process not converged. info = 518
bug - cannot converge. info = 518"
dgorlov
Yes.
My output was identical
