Hello All,
I was able to build and run shortpath example using the nmake and the Makefile to build the example. In the command line window (in Spanish is: Simbolo del sistema, I think Prompt window in English) I ran tbbvars.bat and I fixed PATH and INCLUDE environment variables:
set PATH=C:\Program Files (x86)\Microsoft Visual C++ Compiler Nov 2013 CTP\bin;%PATH%
set INCLUDE=C:\Program Files (x86)\Microsoft Visual C++ Compiler Nov 2013 CTP\include;%INCLUDE%
Then I executed nmake and the executable was built and I ran it.
Then I opened the .sln file in Visual Studio 2013, the first message was that the .vcxproj was going to be updated to vs 2013 and I accepted.
I opened the project's properties window and selected the same compiler as before, I also changed the libraries to ia32\vc12 instead of ia32\vc10
When I compile the project I get 52 errors, 42 of them LNK errors, for some reason VS2013 is not linking correctly.
Does anyone know if is it possible to build tbb examples with vs2013? if it is, where should I check?
I attach the project's files
Thank you.
P.S. List of errors
Error 2 error LNK2001: símbolo externo __purecall sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 3 error LNK2019: símbolo externo "void * __cdecl operator new(unsigned int)" (??2@YAPAXI@Z) sin resolver al que se hace referencia en la función "void __cdecl shortpath(void)" (?shortpath@@YAXXZ) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 4 error LNK2001: símbolo externo "void * __cdecl operator new(unsigned int)" (??2@YAPAXI@Z) sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\msvcprtd.lib(newaop_s.obj) shortpath
Error 5 error LNK2019: símbolo externo "void __cdecl operator delete(void *)" (??3@YAXPAX@Z) sin resolver al que se hace referencia en la función __unwindfunclet$?shortpath@@YAXXZ$0 C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 6 error LNK2001: símbolo externo "void __cdecl operator delete(void *)" (??3@YAXPAX@Z) sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\msvcprtd.lib(locale0_implib.obj) shortpath
Error 7 error LNK2019: símbolo externo _atexit sin resolver al que se hace referencia en la función "void __cdecl `dynamic initializer for 'public: static class std::_Generic_error_category std::_Error_objects<int>::_Generic_object''(void)" (??__E?_Generic_object@?$_Error_objects@H@std@@2V_Generic_error_category@2@A@@YAXXZ) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 8 error LNK2001: símbolo externo _atexit sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\msvcprtd.lib(locale0_implib.obj) shortpath
Error 9 error LNK2019: símbolo externo __imp___invalid_parameter sin resolver al que se hace referencia en la función "public: bool __thiscall std::_Tree_const_iterator<class std::_Tree_val<struct std::_Tree_simple_types<struct std::pair<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const ,class utility::internal::argument> > > >::operator==(class std::_Tree_const_iterator<class std::_Tree_val<struct std::_Tree_simple_types<struct std::pair<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const ,class utility::internal::argument> > > > const &)const " (??8?$_Tree_const_iterator@V?$_Tree_val@U?$_Tree_simple_types@U?$pair@$$CBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@Vargument@internal@utility@@@std@@@std@@@std@@@std@@QBE_NABV01@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 10 error LNK2019: símbolo externo __imp__printf sin resolver al que se hace referencia en la función "void __cdecl print_path(void)" (?print_path@@YAXXZ) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 11 error LNK2019: símbolo externo __imp__exit sin resolver al que se hace referencia en la función __catch$?parse_cli_arguments@utility@@YAXHQAPBDVcli_argument_pack@1@@Z$0 C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 12 error LNK2019: símbolo externo _abs sin resolver al que se hace referencia en la función "bool __cdecl die_toss(unsigned int,unsigned int,class utility::FastRandom &)" (?die_toss@@YA_NIIAAVFastRandom@utility@@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 13 error LNK2019: símbolo externo __imp__free sin resolver al que se hace referencia en la función "void __cdecl std::_DebugHeapDelete<class std::_Facet_base>(class std::_Facet_base *)" (??$_DebugHeapDelete@V_Facet_base@std@@@std@@YAXPAV_Facet_base@0@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 14 error LNK2001: símbolo externo __imp__free sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\msvcprtd.lib(locale0_implib.obj) shortpath
Error 15 error LNK2019: símbolo externo _sqrt sin resolver al que se hace referencia en la función "double __cdecl get_distance(struct point const &,struct point const &)" (?get_distance@@YANABUpoint@@0@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 16 error LNK2019: símbolo externo __imp___hypot sin resolver al que se hace referencia en la función _hypot C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 17 error LNK2001: símbolo externo __imp___hypot sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\msvcprtd.lib(locale0_implib.obj) shortpath
Error 18 error LNK2019: símbolo externo __imp__memmove sin resolver al que se hace referencia en la función "unsigned int * __cdecl std::_Uninit_move<unsigned int,unsigned int,unsigned int>(unsigned int *,unsigned int *,unsigned int *,struct std::_Wrap_alloc<class std::allocator<unsigned int> > &,unsigned int *,struct std::_Scalar_ptr_iterator_tag)" (??$_Uninit_move@III@std@@YAPAIPAI00AAU?$_Wrap_alloc@V?$allocator@I@std@@@0@0U_Scalar_ptr_iterator_tag@0@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 19 error LNK2019: símbolo externo _memcpy sin resolver al que se hace referencia en la función "public: static char * __cdecl std::char_traits<char>::copy(char *,char const *,unsigned int)" (?copy@?$char_traits@D@std@@SAPADPADPBDI@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 20 error LNK2019: símbolo externo __imp__memchr sin resolver al que se hace referencia en la función "char const * __cdecl std::_Find<char const *,char>(char const *,char const *,char const &,struct std::integral_constant<bool,1>)" (??$_Find@PBDD@std@@YAPBDPBD0ABDU?$integral_constant@_N$00@0@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 21 error LNK2019: símbolo externo _memcmp sin resolver al que se hace referencia en la función "public: static int __cdecl std::char_traits<char>::compare(char const *,char const *,unsigned int)" (?compare@?$char_traits@D@std@@SAHPBD0I@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 22 error LNK2019: símbolo externo _memset sin resolver al que se hace referencia en la función "public: static char * __cdecl std::char_traits<char>::assign(char *,unsigned int,char)" (?assign@?$char_traits@D@std@@SAPADPADID@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 23 error LNK2019: símbolo externo _strlen sin resolver al que se hace referencia en la función "public: static unsigned int __cdecl std::char_traits<char>::length(char const *)" (?length@?$char_traits@D@std@@SAIPBD@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 24 error LNK2019: símbolo externo "__declspec(dllimport) public: __thiscall std::exception::exception(char const * const &)" (__imp_??0exception@std@@QAE@ABQBD@Z) sin resolver al que se hace referencia en la función "public: __thiscall std::logic_error::logic_error(char const *)" (??0logic_error@std@@QAE@PBD@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 25 error LNK2019: símbolo externo "__declspec(dllimport) public: __thiscall std::exception::exception(class std::exception const &)" (__imp_??0exception@std@@QAE@ABV01@@Z) sin resolver al que se hace referencia en la función "public: __thiscall std::logic_error::logic_error(class std::logic_error const &)" (??0logic_error@std@@QAE@ABV01@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 26 error LNK2019: símbolo externo "__declspec(dllimport) public: virtual __thiscall std::exception::~exception(void)" (__imp_??1exception@std@@UAE@XZ) sin resolver al que se hace referencia en la función "public: virtual __thiscall std::logic_error::~logic_error(void)" (??1logic_error@std@@UAE@XZ) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 27 error LNK2019: símbolo externo "void __cdecl operator delete[](void *)" (??_V@YAXPAX@Z) sin resolver al que se hace referencia en la función "void __cdecl ReleaseGraph(void)" (?ReleaseGraph@@YAXXZ) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 28 error LNK2019: símbolo externo __imp___CrtDbgReportW sin resolver al que se hace referencia en la función "public: bool __thiscall std::_Tree_const_iterator<class std::_Tree_val<struct std::_Tree_simple_types<struct std::pair<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const ,class utility::internal::argument> > > >::operator==(class std::_Tree_const_iterator<class std::_Tree_val<struct std::_Tree_simple_types<struct std::pair<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const ,class utility::internal::argument> > > > const &)const " (??8?$_Tree_const_iterator@V?$_Tree_val@U?$_Tree_simple_types@U?$pair@$$CBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@Vargument@internal@utility@@@std@@@std@@@std@@@std@@QBE_NABV01@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 29 error LNK2019: símbolo externo "__declspec(dllimport) public: __thiscall std::bad_cast::bad_cast(char const *)" (__imp_??0bad_cast@std@@QAE@PBD@Z) sin resolver al que se hace referencia en la función "class std::ctype<char> const & __cdecl std::use_facet<class std::ctype<char> >(class std::locale const &)" (??$use_facet@V?$ctype@D@std@@@std@@YAABV?$ctype@D@0@ABVlocale@0@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 30 error LNK2019: símbolo externo __imp__SwitchToThread@0 sin resolver al que se hace referencia en la función "public: void __thiscall tbb::internal::atomic_backoff::pause(void)" (?pause@atomic_backoff@internal@tbb@@QAEXXZ) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 31 error LNK2019: símbolo externo __imp__QueryPerformanceCounter@4 sin resolver al que se hace referencia en la función "public: static class tbb::tick_count __cdecl tbb::tick_count::now(void)" (?now@tick_count@tbb@@SA?AV12@XZ) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 32 error LNK2019: símbolo externo __imp__QueryPerformanceFrequency@4 sin resolver al que se hace referencia en la función "private: static __int64 __cdecl tbb::tick_count::interval_t::ticks_per_second(void)" (?ticks_per_second@interval_t@tick_count@tbb@@CA_JXZ) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 33 error LNK2019: símbolo externo __imp___wassert sin resolver al que se hace referencia en la función "int __cdecl utility::internal::step_function_power2_ladder(int,double)" (?step_function_power2_ladder@internal@utility@@YAHHN@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 34 error LNK2001: símbolo externo "public: __thiscall std::bad_cast::bad_cast(class std::bad_cast const &)" (??0bad_cast@std@@QAE@ABV01@@Z) sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 35 error LNK2001: símbolo externo "public: __thiscall std::exception::exception(class std::exception const &)" (??0exception@std@@QAE@ABV01@@Z) sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 36 error LNK2001: símbolo externo "public: virtual __thiscall std::bad_cast::~bad_cast(void)" (??1bad_cast@std@@UAE@XZ) sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 37 error LNK2001: símbolo externo "public: virtual char const * __thiscall std::exception::what(void)const " (?what@exception@std@@UBEPBDXZ) sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 38 error LNK2019: símbolo externo @__security_check_cookie@4 sin resolver al que se hace referencia en la función "public: static void __cdecl `public: void __thiscall utility::cli_argument_pack::parse(unsigned int,char const * * const)'::`5'::throw_unknown_parameter::_(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (?_@throw_unknown_parameter@?4??parse@cli_argument_pack@utility@@QAEXIQAPBD@Z@SAXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 39 error LNK2001: símbolo externo @__security_check_cookie@4 sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\msvcprtd.lib(locale0_implib.obj) shortpath
Error 40 error LNK2019: símbolo externo __CxxThrowException@8 sin resolver al que se hace referencia en la función "public: static void __cdecl `public: void __thiscall utility::cli_argument_pack::parse(unsigned int,char const * * const)'::`5'::throw_unknown_parameter::_(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (?_@throw_unknown_parameter@?4??parse@cli_argument_pack@utility@@QAEXIQAPBD@Z@SAXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 41 error LNK2019: símbolo externo ___CxxFrameHandler3 sin resolver al que se hace referencia en la función __unwindfunclet$?_@throw_unknown_parameter@?4??parse@cli_argument_pack@utility@@QAEXIQAPBD@Z@SAXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z$2 C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 42 error LNK2001: símbolo externo ___CxxFrameHandler3 sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\msvcprtd.lib(locale0_implib.obj) shortpath
Error 43 error LNK2019: símbolo externo ___RTDynamicCast sin resolver al que se hace referencia en la función "public: bool __thiscall tbb::interface7::internal::adaptive_partition_type_base<class tbb::interface7::internal::auto_partition_type>::check_being_stolen(class tbb::task &)" (?check_being_stolen@?$adaptive_partition_type_base@Vauto_partition_type@internal@interface7@tbb@@@internal@interface7@tbb@@QAE_NAAVtask@4@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 44 error LNK2019: símbolo externo __dtoui3 sin resolver al que se hace referencia en la función "bool __cdecl utility::internal::is_power_of_2<double>(double)" (??$is_power_of_2@N@internal@utility@@YA_NN@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 45 error LNK2019: símbolo externo __ltod3 sin resolver al que se hace referencia en la función "public: static double __cdecl tbb::tick_count::resolution(void)" (?resolution@tick_count@tbb@@SANXZ) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 46 error LNK2001: símbolo externo "const type_info::`vftable'" (??_7type_info@@6B@) sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 47 error LNK2019: símbolo externo ___security_cookie sin resolver al que se hace referencia en la función "public: static void __cdecl `public: void __thiscall utility::cli_argument_pack::parse(unsigned int,char const * * const)'::`5'::throw_unknown_parameter::_(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (?_@throw_unknown_parameter@?4??parse@cli_argument_pack@utility@@QAEXIQAPBD@Z@SAXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 48 error LNK2001: símbolo externo ___security_cookie sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\msvcprtd.lib(locale0_implib.obj) shortpath
Error 49 error LNK2001: símbolo externo __fltused sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\shortpath.obj shortpath
Error 50 error LNK2001: símbolo externo __fltused sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\msvcprtd.lib(locale0_implib.obj) shortpath
Error 51 error LNK2001: símbolo externo _mainCRTStartup sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\LINK shortpath
Error 52 error LNK2001: símbolo externo __load_config_used sin resolver C:\tbb43_20150209oss\examples\concurrent_priority_queue\shortpath\msvs\LINK shortpath
Error 53 error LNK1120: 42 externos sin resolver C:\Users\Luis\AppData\Local\Temp\tbb_examples\Debug\shortpath.exe shortpath
Problem solved!
Visual studio created a debug configuration and the project was linking with the release libraries (tbb.lib). I changed the configuration to release and I could compile and ran the example.
hello, is this released visual studio 2013 or CTP of Visual Studio 2015? For second one there is CTP 6 availalbe which was released this week.
--Vladimir
Thank you for your answer, I am using C++ compiler Nov 2013 CTP which includes C++11 features, also I am using VS 2013 express.
I wonder if using the express version is the problem.
Regards.
Problem solved!
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
