Bug with scheduler with TBB 64bits ?
diedler_f_
I recently installed TBB (last version 2017 Update 3) on Windows 64bits and try to test it with a small C++ program :
#include <iostream>
#include <tbb/tbb.h>
int main()
    std::cout << sizeof(int*) << std::endl;
    while (1)
        std::cout << "begin\n";
        tbb::task_scheduler_init init(8);
        std::cout << init.is_active();
    return 0;
The first line shows me that I use a 64bits compiler (MinGW-w64 on Windows) but my program crashes if I try to create more than one instance of task_scheduler_init ...
However, the same program compiled with a 32bits compiler (mingw32-gcc on Windows) works well !
What is the trouble ? The documentation of task_scheduler_init (https://software.intel.com/en-us/node/506296) provides an example highlighted the same problem...
PS : I compiled myself the TBB lib from raw sources :
C:\tbb2017_20161128oss>mingw32-make compiler=gcc info
OS: windows
arch=intel64
compiler=gcc
runtime=mingw6.2.0
tbb_build_prefix=windows_intel64_gcc_mingw6.2.0
Maksim_D_Intel
Hello
This issue already discussed in https://software.intel.com/en-us/forums/intel-threading-building-blocks/topic/641654
You should rebuild TBB with CXXFLAGS="-flifetime-dse=1" to fix this issue.
diedler_f_
Where can I add this command ? Does I need to modify any Makefile (and which Makefile ?) ? (sorry I am a beginner in makefile...)
Another question: What is the purpose of tbbmalloc ? Does I really need it ?
Thanks for your reply
Maksim_D_Intel
mingw32-make compiler=gcc CXXFLAGS="-flifetime-dse=1"
Basically a tbbmalloc is a memory allocator that can work much faster in concurrent environment than a standard allocator.
BTW you can get simple explanation about tbbmalloc and tbbmalloc_proxy from this video https://software.intel.com/videos/1-minute-intro-intel-tbb-malloc-proxy-library .
diedler_f_
It seems to compile well but I have some warnings at the end of the build :
task.o: duplicate section `.rdata$_ZTIN3tbb4taskE[_ZTIN3tbb4taskE]' has different size
arena.o: duplicate section `.rdata$_ZTIN3tbb4taskE[_ZTIN3tbb4taskE]' has different size
scheduler.o: duplicate section `.rdata$_ZTIN3tbb4taskE[_ZTIN3tbb4taskE]' has different size
mingw32-make[1]: Leaving directory 'C:/tbb2017_20161128oss/build/windows_intel64_gcc_mingw6.2.0_release'
What does it mean ?
Thanks for the explanation of tbbmalloc and the link.
Maksim_D_Intel
It's a known issue with MinGW; It shouldn't affect library files
diedler_f_
Thanks a lot, it is now working !
Have a nice day :)
