I used parallel_for in my visual c++ program. When I ran the program, the windows task manager showed that the total threads increased while the CPU usage did not change much (still about 15%).
Do you have any suggestion why this happens? My pc has intel core i7 CPU.
thanks,
Ying
thanks,
Ying
As you are using TBB, you would probably get more expert help on that forum than here.
Thanks. I am new here. Could you please tell me what forum I should post questions about TBB?
You should take a look at this example :
http://msdn.microsoft.com/en-us/library/dd728073.aspx
It is a matrix multiplication. It says that that the function to be parallelized is of crucial importance in load balancing. Make some examples of your own.
Edit : Well PPL is also a joint work with Intel. Ok. Next time it would be great specifying the version of VS you are using. Cheers.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
