- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I am design a dependency node graph base on TBB flow graph.
I am debating if I should design my node's base case as a subclass of one of TBB's predefined node class or design my base class containing one of TBB's predefined node class.
Ultimately, I will wrap my base node derived classes within a UI e.g. Qt, something like this
(1) IsA design
class BaseNode : public oneapi::tbb::flow::continue_node {
or
(2) HasA design
class BaseNode {
oneapi::tbb::flow::continue_node _internal;
What are key questions I need to ask myself to help me select a suitable approach ?
Cheers
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
For your scenario, you can use 2nd design. The steps for using a dependency graph, need to create a graph object, make nodes, add edges, and feed messages into the graph. To express this dependency graph using the flow graph classes, you can use the class continue_node for the nodes and pass messages of type continue_msg. You can also use the join node so that the output of one of the continue_node is put to one of the join_node ports.
Please refer to the below link for more details.
Thanks and Regards,
Pendyala Sesha Srinivas
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks and Regards,
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
