Develop application visual studio2010
mohan_arumugam
hi friends,
can anyone help me how to start an application in intel-tbb by using visual studio-2010 with configuration settings also too..??
Kirill_R_Intel
Mohan,
I assume youre using standalone TBB, without Intel Composer or Intel Composer XE. Some information on installation can be found in INSTALL.txt in TBB archive and Tutorial.pdf here:
http://threadingbuildingblocks.org/documentation.php
Once you have installed Intel TBB, create a new project in VS2010. Then go to Project->Properties->Configuration Properties
In VC++ Directories, go to Include Directories and add TBB include path: /tbb/include. Please refer to the picture below:
Then you should do the same with library directories. In VC++ Directories, go to Library Directories and add TBB library path. For 32-bit version this should be \tbb\lib\ia32\vc10, for 64-bit: \tbb\lib\intel64\vc10.
After this your environment will be ready for creating TBB applications.
Kirill
Alexey-Kukanov
You may also try the plugin we developed for Visual Studio integration of TBB in case the integration provided with Intel Composer is unavailable. The plugin can be downloaded from here: http://threadingbuildingblocks.org/ver.php?fid=129.
