The documentation says that Visual C++ runtime can be dynamically replaced by OneTBB memory allocators. This seems to be true only for standard malloc/free.
Is there any plan to support operators new/delete when using VS2019 ?
Thanks for reaching out to us!
We are forwarding this thread to the concerned internal team, who will guide you further.
Have a Good day!
Thanks & Regards
Goutham
oneTBB documentation says that the following dynamic memory functions are replaced:
- Standard C library functions: malloc, calloc, realloc, free
- Replaceable global C++ operators new and delete
- Microsoft* C run-time library functions: _msize, _aligned_malloc, _aligned_realloc, _aligned_free, _aligned_msize
If you have some difficulties/errors using oneTBB memory allocation, then please provide us the code reproducer.
@mtrekker, there was no feedback from you for more than a week. I assume that the above comment helped you. We are discontinuing monitoring this thread. Please raise a new thread in case of any further issues.
Thanks, Mariya
