2485 Discussions
Error when building the sub_string_finder example
amina-jarraya
I'm a debutant with intel TBB. I download the version 3.0.
I try to build an example (sub_string_finder) but i have the following error :
root@amina-laptop:/home/amina/Bureau/sourcesTBB/tbb30/examples/GettingStarted/sub_string_finder# make
g++ -O2 -DNDEBUG -o sub_string_finder sub_string_finder.cpp -ltbb -lrt
/usr/bin/ld: cannot find -ltbb
collect2: ld returned 1 exit status
make: *** [release] Erreur 1
Have you an idea for this problem ? may be i forget to install something.
Thank you,
sinaelgl
Hello, you have to execute "source /opt/intel/bin/compilervars.sh intel64" (you have to check if compilervars.sh is in that directory, if not replace the path in this command.
