2486 Discussions
How do I reference the tbb::task_group_context object inside a parallel_for loop
tbbuser
tbb::task_group_context tg;
SomeClass someObject;
tbb:: parallel_for(tbb::blocked_range<size_t>(0, num, grainSize),
                   someObject,
                   tbb::simple_partitioner(),
                   tg);
I need to reference tg inside the functor definition of SomeClass so that I can cancel
all the threads under some conditons
lass SomeClass
void operator()(const tbb::blocked_range<size_t>& r)  const{
if (somthing < 0) tg.cancel_group_execution(); }
I get compiler error : "tg" not declared in this scope.
How do i reference the "tg" that is being passed into the parallel_for loop
tbbuser
Thank you for the solution. That works
