Hello everyone!
I have a problem relating to TBB. I recently downloaded it (the Commercial-Aligned Open Source version) onto a Windows XP PC with Microsoft Visual Studio 2008 Express and Microsoft Visual Studio 2010 Express (All four products, Visual Basic, Visual C++, Visual C#, and Visual Web Developer for both installations). I found a tutorial (http://llpanorama.wordpress.com/tbb-tutorial/) but I dont have the required software (Microsoft Visual Studio 2005 Express, which is not supported anymore, or end-of-life, and which also cant be downloaded anymore). How can I install TBB with Visual Studio 2010 Express (or if I have to, Visual Studio 2008 Express)?
Thanks in advance!
Edit: I needed Microsoft Visual Studio 2005 Express for Microsoft Assembler
- « Previous
- 1
- 2
- Next »
Yes, you're correct. I prefer to use IDEs. Does that not work?
[bash]devenv /useenv[/bash]then this environment will be propagated to VS and this should work.
- devenv/useenv
[bash][/bash]
[plain]devenv /useenv[/plain]
its
[plain]vcexpress /useenv[/plain]
the fibonacci sample includes (w/o the full paths (below)) still do not work. :-(
[cpp]#include#include #include #include #include "tbb/task.h" #include "tbb/task_scheduler_init.h" #include "tbb/tick_count.h" #include "tbb/blocked_range.h" #include "tbb/concurrent_vector.h" #include "tbb/concurrent_queue.h" #include "tbb/concurrent_hash_map.h" #include "tbb/parallel_while.h" #include "tbb/parallel_for.h" #include "tbb/parallel_reduce.h" #include "tbb/parallel_scan.h" #include "tbb/pipeline.h" #include "tbb/atomic.h" #include "tbb/mutex.h" #include "tbb/spin_mutex.h" #include "tbb/queuing_mutex.h" #include "tbb/tbb_thread.h"[/cpp]
Not really, I'll convert it now.
I just converted the file I mentioned above in the quote by deleting the linux eol and the dos eol and than pressing
[bash]@echo off REM REM Copyright 2005-2010 Intel Corporation. All Rights Reserved. REM REM This file is part of Threading Building Blocks. REM REM Threading Building Blocks is free software; you can redistribute it REM and/or modify it under the terms of the GNU General Public License REM version 2 as published by the Free Software Foundation. REM REM Threading Building Blocks is distributed in the hope that it will be REM useful, but WITHOUT ANY WARRANTY; without even the implied warranty REM of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the REM GNU General Public License for more details. REM REM You should have received a copy of the GNU General Public License REM along with Threading Building Blocks; if not, write to the Free Software REM Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA REM REM As a special exception, you may use this file as part of a free software REM library without restriction. Specifically, if other files instantiate REM templates or use macros or inline functions from this file, or you compile REM this file and link it with other files to produce an executable, this REM file does not by itself cause the resulting executable to be covered by REM the GNU General Public License. This exception does not however REM invalidate any other reasons why the executable file might be covered by REM the GNU General Public License. REM set SCRIPT_NAME=%~nx0 if (%1) == () goto Syntax SET TBB30_BIN_DIR=%~d0%~p0 SET TBB30_INSTALL_DIR=%TBB30_BIN_DIR%.. :ParseArgs :: Parse the incoming arguments if /i "%1"=="" goto SetEnv if /i "%1"=="ia32" (set TBB_TARGET_ARCH=ia32) & shift & goto ParseArgs if /i "%1"=="intel64" (set TBB_TARGET_ARCH=intel64) & shift & goto ParseArgs if /i "%1"=="vs2005" (set TBB_TARGET_VS=vc8) & shift & goto ParseArgs if /i "%1"=="vs2008" (set TBB_TARGET_VS=vc9) & shift & goto ParseArgs if /i "%1"=="vs2010" (set TBB_TARGET_VS=vc10) & shift & goto ParseArgs if /i "%1"=="all" (set TBB_TARGET_VS=vc_mt) & shift & goto ParseArgs :SetEnv if ("%TBB_TARGET_VS%") == ("") set TBB_TARGET_VS=vc_mt SET TBB_ARCH_PLATFORM=%TBB_TARGET_ARCH%%TBB_TARGET_VS% if exist "%TBB30_BIN_DIR%%TBB_ARCH_PLATFORM%tbb.dll" SET PATH=%TBB30_BIN_DIR%%TBB_ARCH_PLATFORM%;%PATH% if exist "%TBB30_INSTALL_DIR%..redist%TBB_TARGET_ARCH%tbb%TBB_TARGET_VS%tbb.dll" SET PATH=%TBB30_INSTALL_DIR%..redist%TBB_TARGET_ARCH%tbb%TBB_TARGET_VS%;%PATH% SET LIB=%TBB30_INSTALL_DIR%lib%TBB_ARCH_PLATFORM%;%LIB% SET INCLUDE=%TBB30_INSTALL_DIR%include;%INCLUDE% IF ("%ICPP_COMPILER11%") NEQ ("") SET TBB_CXX=icl.exe IF ("%ICPP_COMPILER12%") NEQ ("") SET TBB_CXX=icl.exe goto End :Syntax echo Syntax: echo %SCRIPT_NAME% ^^ echo ^ must be is one of the following echo ia32 : Set up for IA-32 architecture echo intel64 : Set up for Intel 64 architecture echo ^ should be one of the following echo vs2005 : Set to use with Microsoft Visual Studio 2005 runtime DLLs echo vs2008 : Set to use with Microsoft Visual Studio 2008 runtime DLLs echo vs2010 : Set to use with Microsoft Visual Studio 2010 runtime DLLs echo all : Set to use TBB statically linked with Microsoft Visual C++ runtime echo if ^ is not set TBB statically linked with Microsoft Visual C++ runtime will be used. exit /B 1 :End exit /B 0[/bash]
I just tried the new tbbvars.bat, and it worked, except for one thing. *sigh* I tried the fibonacci sample again, and the includes worked (not full paths; e.g. tbb/atomic.h), but there was a error:
[plain]1>------ Build started: Project: fibonacci_tbb, Configuration: Debug Win32 ------ 1> Fibonacci.cpp 1>LINK : fatal error LNK1104: cannot open file 'tbb_debug.lib' ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
[/plain]
Were the lib paths updated?
I'm done! I manually updated the lib path with this command:
[bash]set path=C:Program FilesIntelTBB3.0 Update 1 Commercial-Aligned Releasebinia32vc10;%path%Now the fibonacci sample works!
[/bash]
(My install path will probably be different from other people's install paths. If you've already set the TBB30_INSTALL_DIR, use it like this:
[bash]set path=%TBB_INSTALL_DIR%binia32;%path%[/bash]
A big thank you to all the people who replied!
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
- « Previous
- 1
- 2
- Next »
