I use VC6.0, can I use TBB???
lixianyu
Alexey-Kukanov
TBB does not support VC6, i.e. there is no TBB binaries provided for this version of Visual Studio, neither makefiles supporting TBB build with the VC6 compiler.
Though you could make it a try,I doubt that TBB can be successfully built withVC6, due to the known fact that the VC6 compiler is rather inconsistent with the current C++ standard.
lixianyu
I got a VC8.0.
Thank you so much!
