2485 Discussions
Immediately scheduling task on a different thread
Yonik
I need to launch tasks from a thread that won't be participating in executing them (it's participating in a different event loop and will be blocking).  It seems to take on the order of ~50usec for TBB to run the task on a different thread.  Is there a way to get this work scheduled faster?
Below is some test code.
Results from calling task_group.run() from a non-arena thread:
[2024-04-20 12:10:59.628] [info] [TBBTest.cpp:604] Time until first submit=30
[2024-04-20 12:10:59.628] [info] [TBBTest.cpp:609] latency=56497
[2024-04-20 12:10:59.628] [info] [TBBTest.cpp:609] latency=38618
[2024-04-20 12:10:59.628] [info] [TBBTest.cpp:609] latency=40086
[2024-04-20 12:10:59.628] [info] [TBBTest.cpp:609] latency=41376
[2024-04-20 12:10:59.628] [info] [TBBTest.cpp:609] latency=44238
[2024-04-20 12:10:59.628] [info] [TBBTest.cpp:609] latency=60127
[2024-04-20 12:10:59.628] [info] [TBBTest.cpp:609] latency=60355
[2024-04-20 12:10:59.628] [info] [TBBTest.cpp:609] latency=64096
[2024-04-20 12:10:59.628] [info] [TBBTest.cpp:609] latency=63806
[2024-04-20 12:10:59.628] [info] [TBBTest.cpp:609] latency=64776
Results from calling task_group.run() from within another task:
[2024-04-20 12:04:18.297] [info] [TBBTest.cpp:605] Time until first submit=39873
[2024-04-20 12:04:18.297] [info] [TBBTest.cpp:610] latency=5609
[2024-04-20 12:04:18.297] [info] [TBBTest.cpp:610] latency=990
[2024-04-20 12:04:18.297] [info] [TBBTest.cpp:610] latency=870
[2024-04-20 12:04:18.297] [info] [TBBTest.cpp:610] latency=780
[2024-04-20 12:04:18.297] [info] [TBBTest.cpp:610] latency=690
[2024-04-20 12:04:18.297] [info] [TBBTest.cpp:610] latency=600
[2024-04-20 12:04:18.297] [info] [TBBTest.cpp:610] latency=520
[2024-04-20 12:04:18.297] [info] [TBBTest.cpp:610] latency=420
[2024-04-20 12:04:18.297] [info] [TBBTest.cpp:610] latency=360
[2024-04-20 12:04:18.297] [info] [TBBTest.cpp:610] latency=290
The test code:
// try_put to a multifunction_node in a graph takes about ~50us for the first task to be scheduled
// on a different thread.  Same for task group.
TEST_F(TBBTest, testLatency) {
  // test the time it takes for another thread to work-steal a task from a blocked thread.
  class Msg {
  public:
    Msg() = default;
    Msg(const Msg&) = delete;
    Msg& operator=(const Msg&) = delete;
    std::chrono::time_point<std::chrono::high_resolution_clock> submitTime;
    std::chrono::time_point<std::chrono::high_resolution_clock> processTime;
    void start() {
      submitTime = std::chrono::high_resolution_clock::now();
    void submitted() {
      processTime = std::chrono::high_resolution_clock::now();
  int n = 10;
  std::vector<Msg> messages(n);
  oneapi::tbb::task_group tg;
  // Lets try warming up the arena / task group.  Nope... didn't help.
  int res=0;
  for (int i=0; i<10; i++) {
    tg.run([&]{res++;});
  std::this_thread::sleep_for(std::chrono::milliseconds(1));  // give chance for warmup tasks to run
  auto start = std::chrono::high_resolution_clock::now();
  for (auto& msg : messages) {
    auto* mptr = &msg;
    mptr->start();
    tg.run([mptr]{
      mptr->submitted();
 // submit tasks from within the task group.  Doesn't solve the problem of latency of *this* task though.
  tg.run([&]{
      auto* mptr = &msg;
      mptr->start();
      tg.run([mptr]{
        mptr->submitted();
  // sleep for a bit to give time for tasks to execute *not* in this thread.
  // comment this out to see the difference of scheduling on *this* thread.
  std::this_thread::sleep_for(std::chrono::milliseconds(1000));
  tg.wait();
  // print out the time between our start and when the first task was submitted
  auto elapsed = std::chrono::duration_cast<std::chrono::nanoseconds>(messages[0].submitTime - start).count();
  LOG_INFO("Time until first submit={}", elapsed);
  for (auto &msg : messages) {
    auto submitTime = std::chrono::time_point_cast<std::chrono::nanoseconds>(msg.submitTime).time_since_epoch().count();
    auto processTime = std::chrono::time_point_cast<std::chrono::nanoseconds>(msg.processTime).time_since_epoch().count();
    LOG_INFO("latency={}", processTime - submitTime);
Mark_L_Intel
@Yonik , it seems that your testcase depends on some testing framework: where are TBBTest, testLatency, and LOG_INFO defined?
Yonik
> I was made aware that you submitted the same question directly to our engineering team at GitHub
Yes, sorry.  My message here was originally marked as spam, so I then went to github.
Mark_L_Intel
@Yonik, I was made aware that you submitted the same question directly to our engineering team at GitHub: https://github.com/oneapi-src/oneTBB/issues/1354. Please continue there.
Mark_L_Intel
@Yonik, regarding "My message here was originally marked as spam, so I then went to GitHub," -- I'm not sure how this happened. I've not marked your topic as spam. Your topic is very interesting, and thank you so much for posting your question.
  Please consider posting a cleanup code sample for the benefit of other Forum participants.  Your sample above cannot be compiled. There are leftovers in the code (lines 1-5, 49-60), making understanding the problem difficult.  There is no tg.wait() after the first tg.run (line 33). I'm not sure about the correctness of the sleep statements as they are currently used.
  I understand you are asking: "How to measure the task start-up latency?" If you agree and post a crisp sample showing your solution to this problem (including an important warmup piece), I hope it would interest Forum participants.  I'll try to comment on this, too.
  Meanwhile, if you are interested in thread_group performance studies overall, here is a reference for your records: https://github.com/oneapi-src/oneTBB/issues/313
