I'm testing HashCompare with a constructor on concurrent_hash_map. The original code on the document page(https://software.intel.com/en-us/node/506078) didn't compile. The error is
tbb_example.cc:31:64: error: no matching function for call to ‘tbb::interface5::concurrent_hash_map<std::basic_string<char>, int, VariantHashCompare>::concurrent_hash_map(VariantHashCompare)’
VariantStringTable CaseSensitiveTable(VariantHashCompare(false));
public gist of the code is here: https://gist.github.com/arewedancer/a6ac95ddd800b4da27a943a406bf8226
Hello Jing,
Thank you for reporting the problem. It appears that you have discovered a discrepancy between the documentation and implementation that exists in TBB for years. We will address it; for now, consider that code sample invalid.
