Hi I would like to reuse thread local storage in multiple parallel_for as following:
The Class enumerable_thread_specific(ETS) provides thread local storage that acts like an STL container with one element per thread.
You can get the thread local storage in the tbb::parallel_for_each block. You can use another reference and call the .local() function in tbb::parallel_for_each block.
You can refer to the OneTBB Pro Textbook, page no:165.
Thanks and Regards,
Pendyala Sesha Srinivas
Has the information provided above helped? If yes, could you please confirm whether we can close this thread from our end?
Thanks and Regards,
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
