2485 Discussions
Is there a way to check whether a task_schedular_init object is available in the current thread ?
Rob_Ottenhoff
Hi All,
Or must I do this administation myself ?
Rob
RafSchietekat
Valued Contributor III
A thread can have multiple active task_scheduler_init instances, so if you don't know just add a new one.
Rob_Ottenhoff
Quoting - Raf Schietekat
Hi Raf,
That seemes rather wasteful: I want to check this in a function which can be called from different threads. The function is part of a video tracking system, so it can be called millions of times. If I have to add a task_scheduler_init instance for every call...
Rob
Dmitry_Vyukov
Quoting - Rob Ottenhoff
constructor of task_scheduler_init object will do exactly what you want to do. I.e. check whether scheduler already initialized for current thread, and, if yes, just exit.
RafSchietekat
Why do you need a task_scheduler_init if the code does so little that you are concerned about its cost? Ifthe codeonly uses, e.g., atomics and containers, you don't need task_scheduler_init, but maybe a microbenchmark might help you decide whether you need to worry about this.
Rob_Ottenhoff
Hi Raf,
Thank for your answer, it is most helpful. The behavior of the constructor was not clear to me from the documentation.
I need the task_scheduler_init class to use parallel_reduce. It makes a loop that evaluates the particles in a particle filter parallel. The loop was a performance bottleneck found with a profiler.
Rob
