I'm having some issues with deadlocks while running a tbb::task_group inside a tbb::parallel_for_each.
e.g.
[cpp]class worker_with_deadlock { result result_; tbb::task_group tasks_; public: ~worker_with_deadlock() { tasks_.cancel(); tasks_.wait(); } result run() { tasks_.wait(); auto my_result = std::move(result_); tasks_.run([=] { result_ = do_work(); }); return my_result; } } class worker_without_deadlock { result result_; public: result run() { auto my_result = std::move(result_); result_ = do_work(); return my_result; } } void run_workers() { // This will deadlock? tbb::parallel_for_each(workers.begin(), workers.end(), [&](worker_with_deadlock& worker) { result[worker.tag()] = worker.run(); }); // This will not deadlock? tbb::parallel_for_each(workers.begin(), workers.end(), [&](worker_without_deadlock& worker) { result[worker.tag()] = worker.run(); }); }[/cpp]
Unfortunately I do not have a code which you can use to reproduce the problem with at this moment.
Do you have any ideas as to what might cause this?
I'm afraid this code isn't very helpful to get an understanding of what you are trying to do...
