Before using concurrent_hash_map in parallel code I would like to initialize it with a huge (~million and more) number of keys. I am using concurrent_hash_map::insert() in a loop and observe a dramatic performance degradation with a map growth that is not acceptable for me (please see the log below). STL map grows much faster. Possible solution for me could be some API in concurrent_hash_map allowing a quick serial initialization with no overhead for locks etc., for example unsafe_insert(). If a reason of perofrmance degradation is in the memory allocations, is it possible to preallocate the neccessary size?
-I-: Map size=10000 Time=0.09885 sec Time delta=0.098992 sec
-I-: Map size=20000 Time=0.400218 sec Time delta=0.301233 sec
-I-: Map size=30000 Time=0.938947 sec Time delta=0.538718 sec
-I-: Map size=40000 Time=1.52345 sec Time delta=0.584489 sec
-I-: Map size=50000 Time=2.65433 sec Time delta=1.13086 sec
-I-: Map size=60000 Time=4.69511 sec Time delta=2.04078 sec
-I-: Map size=70000 Time=8.09903 sec Time delta=3.4039 sec
-I-: Map size=80000 Time=13.4937 sec Time delta=5.39462 sec
-I-: Map size=90000 Time=20.6317 sec Time delta=7.13807 sec
-I-: Map size=100000 Time=29.8772 sec Time delta=9.24545 sec
-I-: Map size=110000 Time=41.3442 sec Time delta=11.467 sec
-I-: Map size=120000 Time=54.5208 sec Time delta=13.1766 sec
-I-: Map size=130000 Time=69.704 sec Time delta=15.1832 sec
-I-: Map size=140000 Time=86.9157 sec Time delta=17.2117 sec
-I-: Map size=150000 Time=105.944 sec Time delta=19.0281 sec
-I-: Map size=160000 Time=126.076 sec Time delta=20.1317 sec
-I-: Map size=170000 Time=148.236 sec Time delta=22.1606 sec
-I-: Map size=180000 Time=172.054 sec Time delta=23.8178 sec
-I-: Map size=190000 Time=197.327 sec Time delta=25.2729 sec
-I-: Map size=200000 Time=223.773 sec Time delta=26.4461 sec
-I-: Map size=210000 Time=242.954 sec Time delta=19.1812 sec
-I-: Map size=220000 Time=260.733 sec Time delta=17.7786 sec
-I-: Map size=230000 Time=278.89 sec Time delta=18.157 sec
-I-: Map size=240000 Time=297.838 sec Time delta=18.9478 sec
-I-: Map size=250000 Time=317.326 sec Time delta=19.4883 sec
-I-: Map size=260000 Time=337.068 sec Time delta=19.7423 sec
-I-: Map size=270000 Time=353.319 sec Time delta=16.2504 sec
-I-: Map size=280000 Time=374.058 sec Time delta=20.7392 sec
-I-: Map size=290000 Time=395.48 sec Time delta=21.4224 sec
-I-: Map size=300000 Time=419.424 sec Time delta=23.9436 sec
-I-: Map size=310000 Time=453.983 sec Time delta=34.5595 sec
-I-: Map size=320000 Time=486.734 sec Time delta=32.751 sec
I use concurrent_hash_map with the keys being 24-byte objects, values being integersand hash function returning a unique integer object id. Map size is the number of keys in map.
Fastune shows the most time (>70%) is spent in concurrent_hash_map::lookup() function.
(Correction corrected) I reverted an earlier correction because hash_map is indeed not yet part of the C++ Standard Library (C++0x will have an unordered_map), but some kind of STL hash_map could of course be used as a comparison point (although there are allegedly subtle differences). TBB uses direct chaining, array allocation takes O(n) amortised time (like std::vector) and seems unlikely to be the cause of the problem, pre-allocation would have to assume near-perfect hashing module 64. You also might want to check out the changes I contributed in "concurrent_hash_map::erase", because its fine-grained locking to make concurrent array growth possible will probably have even worse serial performance. :-)
