I can't reproduce this behavior in a small test application.
I try to reinitialize the globaltask_scheduler_init variable to use another number of working threads in my large MFC-based application. I do it this way:
[bash]stop_my_calc();//completely stop all calculation tsi.terminate();//tsi is the global task_scheduler_init variable tsi.initialize(new_number_of_threads); restart_my_calc();//restart calculation[/bash]However the application keep using the previous number of working threads according to the Task Manager.
What can cause it? What is worth to check?
Ivan.
Which version of TBB do you use?
Tried both 2.2 and 3.0.Couldn'tcompile them unfortunately.
The problem is related somehow to the fact that during "stopping" process not all resources are being freed correctly.
A possible reason could be that when you initialize/terminate scheduler, another instance already exists. E.g. this may happen because of auto-initialization that takes place when you work with tasks, task group contexts, or parallel algorithms without scheduler explicitly initialized via task_scheduler_init object.
The problem is solved.
There is a non-TBB working thread in that code that uses (but doesn't host) TBB ones. At the stop step it used to be just killed. Fixed it to allow it to get terminated correctly.
