I have some problems figuring out something that seems very simple: I want to have task instance that would be executed then rescheduled to be rexecuted (as soon as possible).
I exposed there the problems I got trying to write a task that does this :http://stackoverflow.com/questions/11847689/how-to-reschedule-a-concurrent-task#comment15756307_1184...
Can someone give a very simple working example of how to do this?
Does this require having two tasks, one being the continuation of the other?
Problem solved! (as you can see in the link)
I'm reporting here the solution:
this->recycle_to_reexecute();
is deprecated.
Replace by:
this->increment_ref_count();
this->recycle_as_safe_continuation();
Enjoy
P.S.:end of course(in yours case) return NULL from execute.
