Only changed srand(time(NULL)) instead of srand(2) (in the main() function, Ln.186)
int main( int argc, char* argv[] ) { try { tbb::tick_count mainStartTime = tbb::tick_count::now(); // srand(2); srand(time(NULL));
After modifying it, some executions got slower in parallel run.
It looks some different set of data caused this.
Can anyone explain why this behavior happens?
I'm newbie of Intel TBB. So please let me know if I misunderstand something.
seankim@extreme: /mnt/users/seankim/tbb44_20151115oss/examples/concurrent_hash_map/count_strings >
% make
g++ -O2 -DNDEBUG -o count_strings count_strings.cpp -ltbb -lrt
./count_strings
Message from planet 'Ir': Eass, smer is ach brint pan!
Analyzing whole text...
serial run total = 1000000 unique = 36332 time = 0.197769
parallel run total = 1000000 unique = 36332 time = 0.110404
elapsed time : 0.760568 seconds
% ./count_strings
Message from planet 'Yart': Cheng, ster cild tinch att esm!
serial run total = 1000000 unique = 36663 time = 0.196841
parallel run total = 1000000 unique = 36663 time = 0.1076
elapsed time : 0.735285 seconds
% ./count_strings
Message from planet 'Aft': Ped, ash swir an wup bran!
serial run total = 1000000 unique = 36378 time = 0.195981
parallel run total = 1000000 unique = 36378 time = 0.253899
elapsed time : 0.936799 seconds
% ./count_strings
Message from planet 'En': Red, fund flal bet hult cas!
serial run total = 1000000 unique = 36272 time = 0.196101
parallel run total = 1000000 unique = 36272 time = 0.246536
elapsed time : 0.976936 seconds
% ./count_strings
Message from planet 'El': As, jon ess en tan brap!
serial run total = 1000000 unique = 36414 time = 0.195219
parallel run total = 1000000 unique = 36414 time = 0.10454
elapsed time : 0.688636 seconds
With such short runtimes you're going to see more variability from parallel execution, especially without a threads warm-up round before timing starts. Can you also capture one of those random seeds and use it to consistently demonstrate slower performance from the parallel execution? What happens if you repeat the parallel test inside the same program execution, with the same seed value?
