Spatial indexing algorithm and library by TBB
Nishikawa__Mitsuru
Dear all,
I understand TBB is capable to treat recursive algorithm in a parallel manner,
which enable parallel quick sorting.
Therefore, is TBB suitable to spatial indexing algorithm such as R-Tree,
or are there libraries for it to utilize TBB?
I am looking for parallel fastest library of spatial indexing and nn searching.
Kind regards
Nishikawa__Mitsuru
P.S.
Nowadays, many researchers cope with parallel algorithms to build Bounding Volume Hierarchies in GPU.
(c.f. "Fast Parallel Construction of High-Quality Bounding Volume Hierarchies")
I believe TBB is more suited to such a applicatons, AABB tree or so.
If you know the implementation or benefits of parallel spatial indexing by means of TBB,
I would appreciate it if you could tell me.
