[bash]template<>I'm not sure yet how to transparently work with X over ssh (other than ad hoc, by automatically setting X_NOSHMEM based on a predefined macro indicating the environment, assuming that the program will always be used that way), but providing a useful diagnostic for mysteriously black video output is simply a matter of adapting xerr_handler() as follows:
inline atomic_impl::operator atomic_impl ::value_type() const volatile {
converter w;
w.bits = __TBB_Load8(&rep.value);
return w.value;
template<>
inline atomic_impl::value_type atomic_impl ::store_with_release( value_type rhs ) {
converter u;
u.value = rhs;
__TBB_Store8(&rep.value,u.bits);
return rhs;
[/bash]
[bash]int xerr_handler(Display*, XErrorEvent *error)with after_apparent_success_for_XShmAttach a static bool set to true right after XShmAttach apparently succeeded with x_error still 0, which is evidently not always a sufficient test, so without a diagnostic one might lose quite some time finding that out...
#ifndef X_NOSHMEM
if (after_apparent_success_for_XShmAttach && X_ShmAttach==error->minor_code)
fprintf(stderr,
"Problem detected: try rebuilding with X_NOSHMEM defined in " __FILE__ "n");
#endif
x_error = error->error_code;
if(g_video) g_video->running = false;
return 0;
[/bash]
(Added) Actually, I'm not 100% sure whether this was just something I tried or whether it really printed something... but a note in the porting documentation might fit the bill as well, because it still requires intervention.
What compiler reported you the bunch of warnings in tachyon, some new or exotic one? I am trying to decide on the best solution for this.
For the X over SSH issue, if you have some working code for error handling could you please contribute it? I cannot take the code above and put it under our copyright.
"I have reworked the atomic 8-byte operations for 4-byte machine word, so might be nothing special is necessary for doubles anymore."
If it's a change between update 1 and update 2, sorry if I missed that? I'll have another look tonight, but with update 1 it didn't work without this change.
"What compiler reported you the bunch of warnings in tachyon, some new or exotic one? I am trying to decide on the best solution for this."
The most recent Ubuntu, actually (10.04 LTS "Lucid Lynx", on x86), so a lot of people should be exposed to that one. I like the idea behind adding the warning, but of course it means trouble for existing code.
"For the X over SSH issue, if you have some working code for error handling could you please contribute it? I cannot take the code above and put it under our copyright."
OK
Sounds like it's GCC 4.5; I will check then, and find how to suppress the warning (presumably with some pragma).
