TBB flow/dependency graph and work isolation
DimitriosMakris
How can we achieve work isolation among the nodes of a dependency graph or generally a flow graph? I am defining the node as :
tbb::flow::continue_node<tbb::flow::continue_msg> nd (g,[=](const tbb::flow::continue_msg &msg)
   int tid = tbb:this_task_arena::current_thread_index();
  tbb::this_task_arena::isolate([& {
    // do some work with nested parallelism or nested subgraphs
Defining a node as above and using isolate does not prevent tid to get when idle other nodes of the graph? How can we prevent tid to jump out of this node?
Thank you.
Mark_L_Intel
The thread should stay in the isolated arena. If it does not, something is wrong in which case please provide a complete reproducer. For general reference, please see Chapter 12, "Creating an Isolated Region ..." in pro TBB  book freely avaibale for download.
