TBB task allocation assertion
foxcub
I'm trying to traverse a tree via TBB tasks and continuations. The code is below. When I run the code it keeps aborting (frequently, although not always) with the following error:
Assertion t_next->state()==task::allocated failed on line 334 of file ../../src/tbb/custom_scheduler.h Detailed description: if task::execute() returns task, it must be marked as allocated
What can be causing this problem?
template
void
traverse_tree(NodeVisitor& nv)
TreeTraversal& tt = *(new(task::allocate_root()) TreeTraversal(nv));
task::spawn_root_and_wait(tt);
template
class TreeTraversal: public task
public:
struct Continuation;
public:
TreeTraversal(NodeVisitor nv_):
nv(nv_) {}
task* execute()
nv.pre();
Continuation* c = new(allocate_continuation()) Continuation(nv);
c->set_ref_count(nv.size());
for (size_t i = 0; i < nv.size(); ++i)
TreeTraversal& tt = *(new(c->allocate_child()) TreeTraversal(nv.child(i)));
spawn(tt);
if (!nv.size())
return c;
return NULL;
private:
NodeVisitor nv;
template
class TreeTraversal::Continuation: public task
public:
Continuation(NodeVisitor& nv_):
nv(nv_) {}
task* execute() { nv.post(); return NULL; }
private:
NodeVisitor nv;
foxcub
Alexey Kukanov has solved the problem on StackOverflow.
