The query-producer derives a query task, allocating memory and populating it with the statement to be executed, and then pushing it onto a std::queue made thread-safe via a mutex.
[cpp]templateclass ParallelResourcePool { typedef tbb::concurrent_queue<_ResourceType*> Resources; Resources m_resources ; // Derived classes must implement AllocateResource virtual _ResourceType* AllocateResource() = 0 ; // Get a resource off the queue or allocate one. _ResourceType* GetResource() { _ResourceType* resource = NULL ; // Get the first free resource from the queue, if any available. if ( m_resources.try_pop(resource) == true ) return resource ; return AllocateResource() ; } void ReturnResource(_ResourceType* const resource) { m_resources.push(resource) ; } // Derived class must describe how to release a resource. void FreeResource(_ResourceType* const resource) = 0 ; virtual ~ParallelResourcePool() { Resource* resource = NULL ; while ( m_resources.tryPop(resource) ) { FreeResource(resource) ; } } } ; ... class MysqlPool : public ParallelResourcePool { virtual MYSQL* AllocateResource() { MYSQL* conn = threadsafeMysqlOpen() ; return conn ; } } ; static MysqlPool s_mysqlConnections ;
[/cpp]
[cpp]// ParallelResourceUser template defined somewhere else; // it provides a base class that receives the resource pool, // obtains the Resource for this invocation, and then calls // the execute function.[/cpp]
[cpp]class MysqlResourceUser : public ParallelResourceUser{ MysqlResourceUser(std::string& statement) : m_statement(statement) {} virtual bool Execute() const { mysql_real_query(Resource(), m_statement.c_str(), m_statement.length()) ; ... } } ; ... int somefunction() { std::string statement = "SELECT t.field2, t.field2 FROM {0} AS t WHERE {1} = {2} LIMIT 1" ; sqlSubstitute(statement, "mytable", "myfield", "'hello'") ; parallel_work_queue(s_mysqlConnections, new MysqlResourceUser(statement)) ; } [/cpp]
A primary concern is avoiding connection thrashing: I don't want each SQL query to have a connection tear-up/tear-down overhead; currently each worker thread encapsulates and manages its own connection handle.
But I could probably use a concurrent queue of handles and have each query task pull one off the queue, only creating a new one when none is available.
In TBB, you could use enumerable_thread_specific template class to have a connection handle per thread, pretty conveniently.
We develop better support for workoffloading in the next TBB version (and I could provide you some details if you are interested) butstill TBB is unable to compensate for "loss" of worker threads blocked on IOcalls. So maybe using tbb_thread to build your own thread pool is better solution for you at the moment.
On the other hand, if you have an idea about the (average) ratio between working time and waiting time for your threads, you could choose to use TBB scheduler butoversubscribe the machine to the degree defined by that ratio. E.g. if your threads in average spend 3/4 of time doing some work, and 1/4 waiting for DB response, then in theory you would get average system load closer to 100% by multiplying the default number of threads to 4/3, though there would be periods of oversubscription (with some ready threads waiting for a time slot) and undersubscription (with some cores sitting idle). However, any thread pool implementation would have some degree of over- or undersubscription, in my opinion.
[cpp]#pragma omp parallel(but don't spinlock on futexes for pitys sake) { #pragma omp master { /* stuff */ } } void functionCalledFromSomewhereUnderTheAboveCode() { #pragma omp task databaseQuery(...) ; // Let another thread pick it up }[/cpp]Without the OpenMP overhead that comes from having idle worker threads... Right now my understanding leaves me to believe I might be best leaving those as pthread tasks, which is disappointing because I was hoping to use TBB to eliminate platform dependencies.
ISO C++ thread class A thin portable wrapper around OS threads. It's a close approximation of the ISO C++ 200x class thread (Section 30.2 ofhttp://www.open-std.org/jtc1/sc22/wg21/docs/papers/2008/n2691.pdf). Now TBB lets you choose which is best, task-based versus thread-based, for your situation. Threads are typically better than tasks when the "work" is really more waiting than computation, such as for:
- GUI, I/O or network interface threads.
- Threads that need to wait on external events.
- Programs that previously needed to use both native threads and Intel TBB tasks.
"That's what I'm looking for."
Is that tbb_thread you're talking about? It may be a thin wrapper, but there's still a big fat thread underneath (expensive to create and operate). If I had a lot of things to wait for, I would try to consolidate them in a tbb_thread created for that purpose (doing select() or poll() or whatever else is relevant). A task that has to wait for something would create a child task with the relevant information, "spawn" it to the specialised thread (outside of TBB so not actually spawning, just carrying information so not actually executing at any point), and when the information is obtained the specialised thread would destroy the task so that its parent will return from wait_for_all() if blocking, or be spawned the TBB way if used as a continuation (which seems somehow preferable when waiting is involved).
The workaround with mandatory oversubscription suggested by Alexey is indeed the only way to tackle the issue available at the moment. And some of the TBB based appliactions successfully used it. Unfortunately it suffers from several drawbacks that limit its efficiency applicability area.
First for many real world applications (e.g. servers of various kind) the ratio between the time spent waiting and actively working may vary significantly with time. As the result the following negative effects may happen. Let's cosider Alexey's example where we initialize the scheduler with 1/3 of extra threads. If at some moment the time spent in the waiting mode drops from 1/4 to 1/8, you'll get ~20% oversubscription. If on the other hand the blocking time increases from 1/4 to 1/2, you'll get 33% underutilization.
While some degree of oversubscription can be tolerable, underutilization is definitely mauch more harmful. Thus finding appriopriate balance can be tricky in cases when the workload behavior varies in a wide range.
Another issue with this approach is a lack of composability (again, at least so far). If you write a reusable component that relies on this kind of mandatory oversubscription, it may fail to get the necessary amount of threads if the scheduler has already been initialized with other number of threads to the moment the component starts its work.
More robust solution for the blocking operations problem was dabated for quite a long time inside the TBB team, but the limitations of different alterantives held off coming to the consensus. Such a solution first of all requires notifications about when the user code blocks and unblocks.
Requirement (1) ideally needs support from OS, as it is only OS that exactly knows if and when a thread blocks/unblocks. To the moment the only OS providing such a mechanism is recently released 64-bit Win7 (UMS threads). And this is too little for a crossplatform library like TBB.
The only viable alternative to OS support is providing a markup API that would be used by TBB users to delimit operatioons that may block. In response to these calls TBB would dynamically increase internal thread pool size when some thread blocks, and then relinquish extra thread when the original one unblocks.
However solution based on such an API is not free from limitations. First of all it is additional work for the programmers requiring extra diligence in placing the notifications (may be challenging or vexing for large apps). Another inherent shortcoming of the approach is its unreliability, in the sense that potentially blocking operations not always block. For example when data for IO operation are (pre)cached by OS, or when synchronization operation succeeds immediately. In such cases changing thread pool state may introduce significant overhead. To fight this issue we'd need to introduce some timeouts for new threads activation that will decrease the hardware utilization to some extent.
Another problem is what to do with a replacemnt thread when the original one unblocks. The issue here is that the new thread may grab a large piece of work, and especially in case of nested parallelism (a frequent usage model for TBB apps) it will not be able to stop until it finishes it all. This obviously leads to the oversubscription that may reach a significant level in soem cases.
To mitigate this new problem we could block the original thread in its unblock notification until the number of active threads drops enough. This would cost us additional synchronization, and what is worse can even result in a deadlock if the blocking operation with surrounding notifications is done from under the lock.
Thus as you can see there are a number of pitfalls on the way of introducing blocking operations support in TBB (let alone the cost of extra synchronization that may have to be added into the TBB task scheduler).
Anyway it would be interesting to hear you opinion on whether the manual notification based approach (with all its limitations) appears to be useful to you?
Can you explain what you think is wrong with my suggestion?
When I said "the only way" I meant the solution using standard TBB workers pool. In your variant the user would need to manually implement generic thread pool infrastructure, which is a nuisance at the very least :) . Besides TBB does not provide complete abstraction for platform specific synchronization mechanisms (like events and waiting functions on Windows, and poll/epoll on Nixes).
As an additional note, instead of passing TBB task to the custom pool thread, it would be better to pass a reference to the waiting task, and directly decrement its refcount upon blocking operation completion. Doing so will save you overhead of a task creation/destruction, and what is much more important will prevent automatic initialization of the TBB task scheduler object in the custom pool thread when task::destroy() method is called. And the scheduler initialization is not the fastest thing in the world :)
It was precisely the reasons you've outlined that lead me to this initial conclusion/post :) Obviously the problem doesn't go away just because TBB is not used, it just becomes more opaque: the TBB scheduler makes assumptions about the workload being done and assigns work, but then fails to get the intended parallelism because of native thread scheduling occuring in other parts of the application.
Honestly - until hardware engineers can be coaxed into bridging this gap with us we are going to have to work around the limitations imposed by software spending CPU cycles guessing what hardware to use :)
In most of my experience (I've been a "hobbyist paralleist" since I was 14 in 1985 when I developed my own multi-tasking OS in 680x0 assembler) async workers are very low priorty.
For the purpose of this thread, I am primarily considering deferable tasks that you simply wish not to delay the main thread. I think it would be perfectly acceptable to exclude these from nested parallelism. My aim is to initiate fresh migration to TBB.
The most common parallelism tasks for non-cpu intense work are things like DNS queries, file operations, database operations, network I/O, I/O-to-hardware offloading and reflection (self-monitoring, auditing, logging).
Such systems tend to lack the quantities of cpu-intense work to demand a full allocation of modern-cpu cores. Consider a web-server that will be delivering encrypted and/or compressed pages.
This could be quite well suited to OpenMP 3.0 sections and tasking to parallelize the polling of network I/O and handling the tasking of responses (accept new connection, close connections that raised errors, drain writes to connections ready for more data, process completed reads).
It will generate some eminently parallizable workloads when it encrypts and compresses a 500Kb response. But it is unlikely to want to do so at the cost of all other activity.
Additionally, in the case of "server" systems, one only has to glance at the list of "server" offerings from vendors like Dell or Newegg to see that "server" most frequently equals "multi-cpu" (all of our servers have two cpus with multiple cores each). If there are 16 CPU cores of which 14 are in use, and TBB needs 2 cores for threads, does it know/need to pick two on the same CPU?
Anyway - to the matter of aiding such applications transition to TBB, to consolidate where they get their threading, I think some markup might be useful, but I think that should be done up-front. It will simplify the considerations you and the developer need to give. The worker pool concept can then be generalized, but the operation of the pools will be singular for a given application.
I can see two scenarios for this usage:
1. Deferal workers: Async work is queued as needed, but is then processed on demand:
[cpp]int main() { initialize() ;perhaps the user might specify a maximum time for the workers to run.
// Manual scheduling of worker activities.
tbb::set_worker_deferal(true) ;
// Raise an error when a worker has not exited
// after two calls to schedule_workers.
tbb::set_worker_max_cycles(2) ;
while ( running ) { application_work() ; // Allow 2.5ms for worker execution; after this
// time, schedule_workers returns 'false' if any
// workers have not terminated, or 'true' if
// there is 0 work left outstanding and zero
// workers still active. It may return sooner.
tbb:schedule_workers(2500) ; } } [/cpp]
Pro: The deferal work does not interfere with other operations, and any non-intensive work done during the "application work" phase will not interfere with other operating system activity etc: I've come across a lot of intensive applications which have to
[cpp]#if defined(WIN32) || defined(WIN64) Sleep(0); #else pthread_yield(); #endif[/cpp]to let the OS do its thing and prevent the application stalling out the machine. (Particularly MacOS and Windows)
Pro: Deferred work actions benefit from cache hotness by running simultaneously.
Cons: Deferred work may take significantly longer to be executed.
Cons: Worker threads that take too long may block.
Options: Rather than a monolithic operator(), a very simple FSM could be used that allows the worker to return either tbb::Worker::Completed vs tbb::Worker::Yielding. Yielding threads would be re-queued and then an additional operator invoked on subsequent calls to schedule_workers to see if they need to resume yet -- as with the case of handing a single, huge amount of write data to a worker, which will then perform non-blocking IO operations, yield when the IO buffers are full, and check to see if the IO buffers have empited sufficient for another write...
2. Parallel Workers: Async work is handled on dedicated threads using mutex lock/signal to dispatch work to those threads.
[cpp]struct MySQLUpdate : public tbb::PoolWorker(Using something like the class/struct prototypes in my first post){ MySQLUpdate(const std::string& srcQuery) : query(srcQuery) {} std::string query ;
// Takes a "Split" to indicate this is executed in parallel
virtual tbb::PoolWorker::ReturnType operator()(tbb::Split&) const { mysql_real_query(GetResource(), query.c_str(), query.length()) ; if ( got_mysql_error )
return tbb::PoolWorker::Completed ;
// Return one of Yielding, Completed or Join.
return tbb::PoolWorker::Join ;
// Takes a dummy "Join" to indicate this is to be executed by the
// master thread when tbb::consume_worker_results() is called.
virtual void operator()(tbb::Join&) const
update_next_hearbeat_time() ;
tbb::set_worker_deferral(false) ;
// Crude "delegate workers to the Nth cpu". But obviously,
// you would probably want to check the CPUs had more than
// one core too :)
uint32_t cpus = tbb::get_num_cpus() ;
if ( cpus == 1 )
log("CAUTION: Only one CPU detected, performance may be degradedn") ;
tbb::set_worker_cpu_affinity(cpus) ;
while ( running )
// 0 to indicate we want all worker results consumed;
// otherwise a uSecond value for maximum time to
// spend processing Joined results.
tbb::consume_worker_results(0) ;
tbb::parallel_work_queue(mysqlConnectionResources
, new MySQLUpdate("update server_heartbeat set last_beat = NOW()") ;
[/cpp]
These two models ought to cover a huge swatch of cases where people are currently using alternative threading packages; it ought to fairly closely match most of the models they use to ease transition, and it should create a workable base on which to build and integrate future models where workers can become more computationally intesive by drawing in new users to TBB to comment and feedback on how their requirements.
I think part of the reason the debates you mentioned came to no workable conclusion is that developers are looking to you for guidance on how they should parallelize. What they previously knew about parallelization has changed with modern CPU architecture, so they stick with what they already know (the self-same problem in getting single-threaded developers to transition to paralleism in the first place :).
Also, a key element here that you may have overlooked is this: You don't have to worry about the efficiency of these workers or their processing. Elegance and ease-of use are a higher order of priority. It may even think of these as "laborers" or "interns" instead of workers; "workers" tends to conjur up the idea of highly efficient worker ants :)
As a primarily network/systems/server developer, I envy my desktop peers for all the CPU extensions they've gotten. All that multiple cores has done for me is add to my personal workload due to the absence of hardware support for work-distribution. 25 years since I wrote my first task scheduler, and here we sit still having to design algorithms to ask the CPUs to please execute their code in their own preferred manner! :)
That was pretty much "finger in the air" thinking out loud. Obviously there might be better ways of doing it such as having a worker return NULL for "I'm finished" or a function object if it wants to pick up at a different code point.
- Oliver
Oliver,
The following is an outline of a low overhead code that might fill your needs.
Determine a worst case upper limit on the number of connections you want to permit your application to make. Your application will not necessarily make this number of connections. This number of connections may or may not relate to the number of auxiliary threads outside the TBB thread pool you allocate to process queries (which may vary depending on if queries are synchronous or can be asynchronous).
Once the upper limit on number of connections has been determined you allocate (or pre-size declare) two arrays of pointers to query objects (nullify pointers). (allocate a 3rd array when asynchronous requests can be made).
One table will hold pointers to available query objects, the other table contains table of queued queries. (3rd table when asynchronous requests can be made contain pending query pointers).
You maintain a count of the number of allocated query objects.
Initially you may decide to pre-connect 0-n connections. Connection allocation is performed by allocating the next sequential query object your design (query objects numbered 0-n), make connection, then place pointer to object into array of available query objects
A TBB thread wishing to make a query searches the available query objects table for non-NULL pointer, when found an XCHG of NULL with pointer is made, if non-NULL pointer obtained, then the TBB thread owns the query object. The remaining work for the TBB thread is to fill in the query object and to insert the object pointerinto the pending query table at index
The auxiliary threads processing the queries loop on checking overflow pending queries, if not NULL, then a decision is made to if to expand the number of query connections or not to expand the number of query connections. If expansion is recommended then thread sets expansion pending (to inhibit overexpansion) and makes additional connection(s) and potentially increasing query thread pool size. As expansion occurs the new available query nodes are added to the table of available query nodes, then finally releasing the expansion pending flag.
When overflow pending queries is NULL (or expansion in progress is detected), the query thread searches the pending query table for non-NULL entry, if found, it performs an XCHG with NULL, if non-NULL pointer returned then the query thread owns the query node and the query is made.
Should the SQL system permit asynchronous queries then the design would contain a 3rd table of query node pointers to hold query made but pending nodes. The 3rd table would receive the query node pointer. Should the query thread find an empty table then it decrements the count of active query threads then suspends itself.
When the query completes (either synchronously or asynchronously) then the results (or failure) is passed back to the TBB worker threads by way of linked list, table or FIFO queue.
The design goal is to have low inter-thread communication overhead, and manageable number of connections and non-blocking operation for TBB threads. Excepting when query threads need to be awoken, the TBB thread overhead becomes search a table + a single XCHG (which is interlocked) + time to fill query node + 1 write of pointer into pending query table.
A lot of the coding details remain to be filled in, but this should get you started.
Jim Dempsey
Could you please elaborate what is the problem(s)?
[cpp]// ZeroMQ / Async::Worker example. // Oliver 'kfs1' Smith// Uses clock_gettime which, under linux, requires -lrt // Because the example contains a lot of additional // code (for benchmarking) I have highlighted the key // sections of the main() function with lines of ///s. #include "async-worker.h" // The Asyc:: classes. #include // For std::vector. #include // For printf #include // For rand #include // For sin, cos, etc #include // Timing functions. #include // For uint64_t. typedef uint64_t Number ; typedef std::vector< Number > Numbers ; class CrunchNumbersRange : public Async::RunAndReturn { public: CrunchNumbersRange(const Numbers::iterator& start, const Numbers::iterator& end, Number* finalDestination) : m_start(start) , m_end(end) , m_sum(0) , m_finalDestination(finalDestination) {} public: virtual void Work() const { Numbers::iterator it ; for ( it = m_start ; it != m_end ; ++it ) { m_sum += *it ; } } public: virtual void Result() { // Add our calculated value to the accumulator. *m_finalDestination += m_sum ; } private: Numbers::iterator m_start, m_end ; private: mutable Number m_sum ; private: Number* m_finalDestination ; } ; int main(int argc, const char* const argv[]) { static const size_t NumberOfElements = 20000000 ; static const size_t GroupSize = 8192 ; Numbers numbers ; numbers.resize(NumberOfElements) ; for ( size_t i = 0 ; i < NumberOfElements ; ++i ) { numbers = (rand() & 65535) + 1 ; } uint64_t parallelResult = 0 ; // Dispatch groups of numbers to workers. Numbers::iterator it = numbers.begin() ; do { Numbers::iterator end = std::min(it + GroupSize, numbers.end()) ; Async::Queue(new CrunchNumbersRange(it, end, ¶llelResult)) ; it = end ; } while ( it != numbers.end() ) ; // Wait for all the results, calling Result() on each // returned object to produce a total. Async::GetResults() ; printf("Done. Calculated sum as %lu.n", (unsigned long int)parallelResult) ; return 0 ; } [/cpp]
[cpp]////// Version one: just connect to a local worker. zmq::socket_t outSocket(zmqContext, ZMQ_REQ) ; outSocket.connect("inproc://my-name-for-this-socket") ; // Send a message directly from my data with zero copies. zmq::message_t msg(myData, sizeof(myData)) ; outSocket.send(msg, 0) ; ////// Version two: connect instead to a forwarder that may forward messages ////// across processes or machines. zmq::socket_t outSocket(zmqContext, ZMQ_REQ) ; outSocket.connect("tcp://192.168.0.5:2342") ; // Send a message directly from my data with zero copies. zmq::message_t msg(myData, sizeof(myData)) ; outSocket.send(msg, 0) ; [/cpp]
Correction: They provide zmq_queue (for transparent client/server muxing/load balancing/scaling), zmq_forwarder is for the multicast/pub-sub pattern allowing you to offload the filtering/broadcasting of messages (i.e. you can achieve multicast over TCP by connecting to a forwarder) and zmq_streamer for transparent distribution of work between local or remote workers with smart, fair scheduling.
This gives you the message-passing parallel-scalability of Erlang in the language - or languages - of your choice.
[cpp]zmq::context_t zmqContext(1) ; // Allocate 1 IO thread. zmq::socket_t socket(ZMQ_DOWNSTREAM) ; // We're sending data downstream to workers. // Create a low-overhead, zero-copy, lock-free // connection to local worker threads. socket.bind("inproc://thread-workers") ; // But also accept connections from remote machines // that want to do work for us - on the same zmq endpoint. socket.bind("tcp://0.0.0.0:12345") ; //// BEGIN PSEUDO CODE //// // Divide our work into chunks. for ( chunk_iterator it = work.begin() ; it != work.end() ; ++it ) { zmq::message_t workMessage(it) ; socket.send(&workMessage) ; } //// END PSEUDO CODE //// [/cpp]Despite the socket-like API, the dispatch of work to worker threads is actually extremely efficient. Obviously you'd need some really hefty workloads to justify sending work out over the Internet.
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
