after-build tests partially fail
Leonard_K_
Two after-build tests fail for the intel TBB source:
make rml (which by default also makes rml_test - which fails):
./test_rml_mixed.exe
Assertion my_make_server_routine failed on line 86 of file ../../src/rml/client/rml_factory.h
../../build/Makefile.rml:150: recipe for target 'rml_test' failed
make[1]: *** [rml_test] Aborted (core dumped)
make[1]: Leaving directory '/path_to_src_dir/tbb43_VERSIONoss/build/linux_intel64_gcc_cc5.2.0_libc2.22_kernel4.2.0_debug'
Makefile:50: recipe for target 'rml' failed
make: *** [rml] Error 2
VERSION is confirmed to atleast be either 20150611 or 20150728.
Also the make-target `test` fails, at some point:
TBB Warning: RML might limit the number of workers to 7 while 15 is requested.
Call stack info (6):
./test_tbb_fork.exe(_Z16print_call_stackv+0x44)[0x4045ba]
./test_tbb_fork.exe(_Z11ReportErrorPKciS0_S0_+0x1d)[0x4046a3]
./test_tbb_fork.exe(_Z8TestMainv+0x377)[0x404f45]
./test_tbb_fork.exe(main+0x2d)[0x404a1a]
/usr/lib/libc.so.6(__libc_start_main+0xf0)[0x7f976d601610]
./test_tbb_fork.exe(_start+0x29)[0x4044a9]
../../src/test/test_tbb_fork.cpp:195, assertion 0: Hang after fork
../../build/Makefile.test:251: recipe for target 'test_tbb_plain' failed
make[1]: *** [test_tbb_plain] Aborted (core dumped)
make[1]: Leaving directory '/path_to_src_dir/tbb43_VERSIONoss/build/linux_intel64_gcc_cc5.2.0_libc2.22_kernel4.1.8_debug'
Makefile:44: recipe for target 'test' failed
make: [test] Error 2 (ignored)
The error in the `rml` target is that the assertion failed that 'factory' could not be opened - at least that's the comment above the critical line:
Same thing for the VERSION.
I could not check why both assertions fail (first: fail to open `factory`; second: thread hangs even after pkill and reaches code that shouldn't be reached). The issue not only exists on GCC5 but I also tested it on GCC4.9.
Any idea why the tests fail? Bug in the source or libraries?
Other links: https://bugs.archlinux.org/task/46160
Alexandr_K_Intel1
This is *not* the rml I'm just running 'make && make test'. Could you please double-check this? I.e., TBB_VERSION=1 LD_LIBRARY_PATH=. ./test_tbb_fork.exe 2>&1|grep RML returns TBB: RML shared when shared RML is in use, and TBB: RML private when no shared RML found.
sl1pkn07
Hi
Archlinux update the TBB stack to 2021.4 in [testing] (include tbb4py)
update to build script for use system tbb instead bundled (downloaded from APT) get the same output (NULL platform behavior) when run clinfo
strace about missing IMRL library now is complete
openat(AT_FDCWD, "/usr/lib/libirml.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 P\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=51056, ...}, AT_EMPTY_PATH) = 0
close(3)                                = 0
munmap(0x7f3143bad000, 366360)          = 0
mmap(NULL, 57592, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f3143bf8000
mprotect(0x7f3143bfd000, 28672, PROT_NONE) = 0
mmap(0x7f3143bfd000, 16384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x7f3143bfd000
mmap(0x7f3143c01000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x7f3143c01000
mmap(0x7f3143c04000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb000) = 0x7f3143c04000
mmap(0x7f3143c06000, 248, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f3143c06000
close(3)
so idk what happen here
greetings
NoorjahanSk_Intel
Could you please let us know the command used to generate the log mentioned in the previous post?
Does this mean that your issue regarding the IMRL library was resolved?
Could you please do let us know the exact issue you are facing now?
Thanks & Regards,
Noorjahan.
sl1pkn07
Hi
simply `strace <app>`
`strace clinfo`
the missing library is now resolved, because Archlinux TBB package include it
https://archlinux.org/packages/testing/x86_64/tbb/files/
the same issue without the IMRL library (the root of the problem i think in the first time)
`clinfo` show:
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  No platform
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   No platform
  clCreateContext(NULL, ...) [default]            No platform
  clCreateContext(NULL, ...) [other]              Success [INTEL]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  Success (1)
    Platform Name                                 Intel(R) OpenCL
    Device Name                                   Intel(R) Xeon(R) CPU E5-2650 v4 @ 2.20GHz
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU)  Success (1)
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
NoorjahanSk_Intel
Thanks for providing the details.
Could you please confirm whether the log provided in your previous reply is a complete log?
If not please provide us a complete log so that it would be helpful for us to get some more insights.
Please find the attached file for the output of "strace clinfo" command that we got on our end.
could you please let us know if you are looking for any specific information from the output of clinfo?
Thanks & Regards,
Noorjahan.
sl1pkn07
Hi
no, is not complete, is only the last part. the complete log is
only clinfo:
└───╼  clinfo
Number of platforms                               2
  Platform Vendor                                 Intel(R) Corporation
  Platform Version                                OpenCL 3.0 LINUX
  Platform Profile                                FULL_PROFILE
  Platform Extensions                             cl_khr_spirv_linkonce_odr cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_khr_il_program cl_intel_unified_shared_memory_preview cl_intel_subgroups cl_intel_subgroups_char cl_intel_subgroups_short cl_intel_subgroups_long cl_intel_spirv_subgroups cl_intel_required_subgroup_size cl_intel_exec_by_local_thread cl_intel_vec_len_hint cl_intel_device_partition_by_names cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer
  Platform Extensions with Version                cl_khr_spirv_linkonce_odr                                        0x400000 (1.0.0)
                                                  cl_khr_icd                                                       0x400000 (1.0.0)
                                                  cl_khr_global_int32_base_atomics                                 0x400000 (1.0.0)
                                                  cl_khr_global_int32_extended_atomics                             0x400000 (1.0.0)
                                                  cl_khr_local_int32_base_atomics                                  0x400000 (1.0.0)
                                                  cl_khr_local_int32_extended_atomics                              0x400000 (1.0.0)
                                                  cl_khr_int64_base_atomics                                        0x400000 (1.0.0)
                                                  cl_khr_int64_extended_atomics                                    0x400000 (1.0.0)
                                                  cl_khr_byte_addressable_store                                    0x400000 (1.0.0)
                                                  cl_khr_depth_images                                              0x400000 (1.0.0)
                                                  cl_khr_3d_image_writes                                           0x400000 (1.0.0)
                                                  cl_khr_il_program                                                0x400000 (1.0.0)
                                                  cl_intel_unified_shared_memory_preview                           0x400000 (1.0.0)
                                                  cl_intel_subgroups                                               0x400000 (1.0.0)
                                                  cl_intel_subgroups_char                                          0x400000 (1.0.0)
                                                  cl_intel_subgroups_short                                         0x400000 (1.0.0)
                                                  cl_intel_subgroups_long                                          0x400000 (1.0.0)
                                                  cl_intel_spirv_subgroups                                         0x400000 (1.0.0)
                                                  cl_intel_required_subgroup_size                                  0x400000 (1.0.0)
                                                  cl_intel_exec_by_local_thread                                    0x400000 (1.0.0)
                                                  cl_intel_vec_len_hint                                            0x400000 (1.0.0)
                                                  cl_intel_device_partition_by_names                               0x400000 (1.0.0)
                                                  cl_khr_spir                                                      0x400000 (1.0.0)
                                                  cl_khr_fp64                                                      0x400000 (1.0.0)
                                                  cl_khr_image2d_from_buffer                                       0x400000 (1.0.0)
  Platform Numeric Version                        0xc00000 (3.0.0)
  Platform Extensions function suffix             INTEL
  Platform Host timer resolution                  1ns
  Platform Name                                   NVIDIA CUDA
  Platform Vendor                                 NVIDIA Corporation
  Platform Version                                OpenCL 3.0 CUDA 11.5.100
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info
  Platform Extensions with Version                cl_khr_global_int32_base_atomics                                 0x400000 (1.0.0)
                                                  cl_khr_gl_sharing                                                0x400000 (1.0.0)
                                                  cl_nv_compiler_options                                           0x400000 (1.0.0)
                                                  cl_nv_device_attribute_query                                     0x400000 (1.0.0)
                                                  cl_nv_pragma_unroll                                              0x400000 (1.0.0)
                                                  cl_nv_copy_opts                                                  0x400000 (1.0.0)
                                                  cl_nv_create_buffer                                              0x400000 (1.0.0)
                                                  cl_khr_device_uuid                                               0x400000 (1.0.0)
                                                  cl_khr_pci_bus_info                                              0x400000 (1.0.0)
  Platform Extensions function suffix             NV
  Platform Host timer resolution                  0ns
Number of devices                                 1
  Device Vendor                                   Intel(R) Corporation
  Device Vendor ID                                0x8086
  Device Version                                  OpenCL 3.0 (Build 0)
  Device Numeric Version                          0xc00000 (3.0.0)
  Driver Version                                  2021.12.9.0.24_005321
  Device OpenCL C Version                         OpenCL C 3.0
  Device OpenCL C all versions                    OpenCL C                                                         0xc00000 (3.0.0)
                                                  OpenCL C                                                         0x800000 (2.0.0)
                                                  OpenCL C                                                         0x402000 (1.2.0)
                                                  OpenCL C                                                         0x401000 (1.1.0)
                                                  OpenCL C                                                         0x400000 (1.0.0)
  Device OpenCL C features                        __opencl_c_3d_image_writes                                       0xc00000 (3.0.0)
                                                  __opencl_c_atomic_order_acq_rel                                  0xc00000 (3.0.0)
                                                  __opencl_c_atomic_order_seq_cst                                  0xc00000 (3.0.0)
                                                  __opencl_c_atomic_scope_device                                   0xc00000 (3.0.0)
                                                  __opencl_c_atomic_scope_all_devices                              0xc00000 (3.0.0)
                                                  __opencl_c_device_enqueue                                        0xc00000 (3.0.0)
                                                  __opencl_c_generic_address_space                                 0xc00000 (3.0.0)
                                                  __opencl_c_fp64                                                  0xc00000 (3.0.0)
                                                  __opencl_c_images                                                0xc00000 (3.0.0)
                                                  __opencl_c_int64                                                 0xc00000 (3.0.0)
                                                  __opencl_c_pipes                                                 0xc00000 (3.0.0)
                                                  __opencl_c_program_scope_global_variables                        0xc00000 (3.0.0)
                                                  __opencl_c_read_write_images                                     0xc00000 (3.0.0)
                                                  __opencl_c_subgroups                                             0xc00000 (3.0.0)
                                                  __opencl_c_work_group_collective_functions                       0xc00000 (3.0.0)
  Latest comfornace test passed                   v2021-08-16-00
  Device Type                                     CPU
  Device Profile                                  FULL_PROFILE
  Device Available                                Yes
  Compiler Available                              Yes
  Linker Available                                Yes
  Max compute units                               40
  Max clock frequency                             2200MHz
  Device Partition                                (core)
    Max number of sub-devices                     40
    Supported partition types                     by counts, equally, by names (Intel)
    Supported affinity domains                    (n/a)
  Max work item dimensions                        3
  Max work item sizes                             8192x8192x8192
  Max work group size                             8192
  Preferred work group size multiple (device)     128
  Preferred work group size multiple (kernel)     128
  Max sub-groups per work group                   2048
  Sub-group sizes (Intel)                         4, 8, 16, 32, 64
  Preferred / native vector sizes
    char                                                 1 / 32
    short                                                1 / 16
    int                                                  1 / 8
    long                                                 1 / 4
    half                                                 0 / 0        (n/a)
    float                                                1 / 8
    double                                               1 / 4        (cl_khr_fp64)
  Half-precision Floating-point support           (n/a)
  Single-precision Floating-point support         (core)
    Denormals                                     Yes
    Infinity and NANs                             Yes
    Round to nearest                              Yes
    Round to zero                                 No
    Round to infinity                             No
    IEEE754-2008 fused multiply-add               No
    Support is emulated in software               No
    Correctly-rounded divide and sqrt operations  No
  Double-precision Floating-point support         (cl_khr_fp64)
    Denormals                                     Yes
    Round to zero                                 Yes
    Round to infinity                             Yes
    IEEE754-2008 fused multiply-add               Yes
  Address bits                                    64, Little-Endian
  Global memory size                              135202459648 (125.9GiB)
  Error Correction support                        No
  Max memory allocation                           33800614912 (31.48GiB)
  Unified memory for Host and Device              Yes
  Shared Virtual Memory (SVM) capabilities        (core)
    Coarse-grained buffer sharing                 Yes
    Fine-grained buffer sharing                   Yes
    Fine-grained system sharing                   Yes
    Atomics                                       Yes
  Minimum alignment for any data type             128 bytes
  Alignment of base address                       1024 bits (128 bytes)
  Preferred alignment for atomics
    SVM                                           64 bytes
    Global                                        64 bytes
    Local                                         0 bytes
  Atomic memory capabilities                      relaxed, acquire/release, sequentially-consistent, work-group scope, device scope, all-devices scope
  Atomic fence capabilities                       relaxed, acquire/release, sequentially-consistent, work-item scope, work-group scope, device scope, all-devices scope
  Max size for global variable                    65536 (64KiB)
  Preferred total size of global vars             65536 (64KiB)
  Global Memory cache type                        Read/Write
  Global Memory cache size                        262144 (256KiB)
  Global Memory cache line size                   64 bytes
  Image support                                   Yes
    Max number of samplers per kernel             480
    Max size for 1D images from buffer            2112538432 pixels
    Max 1D or 2D image array size                 2048 images
    Base address alignment for 2D image buffers   64 bytes
    Pitch alignment for 2D image buffers          64 pixels
    Max 2D image size                             16384x16384 pixels
    Max 3D image size                             2048x2048x2048 pixels
    Max number of read image args                 480
    Max number of write image args                480
    Max number of read/write image args           480
  Pipe support                                    Yes
  Max number of pipe args                         16
  Max active pipe reservations                    6553
  Max pipe packet size                            1024
  Local memory type                               Global
  Local memory size                               32768 (32KiB)
  Max number of constant args                     480
  Max constant buffer size                        131072 (128KiB)
  Generic address space support                   Yes
  Max size of kernel argument                     3840 (3.75KiB)
  Queue properties (on host)
    Out-of-order execution                        Yes
    Profiling                                     Yes
    Local thread execution (Intel)                Yes
  Device enqueue capabilities                     supported, replaceable default queue
  Queue properties (on device)
    Profiling                                     Yes
    Preferred size                                4294967295 (4GiB)
    Max size                                      4294967295 (4GiB)
  Max queues on device                            4294967295
  Max events on device                            4294967295
  Prefer user sync for interop                    No
  Profiling timer resolution                      1ns
  Execution capabilities
    Run OpenCL kernels                            Yes
    Run native kernels                            Yes
    Non-uniform work-groups                       Yes
    Work-group collective functions               Yes
    Sub-group independent forward progress        No
    IL version                                    SPIR-V_1.0
    ILs with version                              SPIR-V                                                           0x400000 (1.0.0)
    SPIR versions                                 1.2
  printf() buffer size                            1048576 (1024KiB)
  Built-in kernels                                (n/a)
  Built-in kernels with version                   (n/a)
  Device Extensions                               cl_khr_spirv_linkonce_odr cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_khr_il_program cl_intel_unified_shared_memory_preview cl_intel_subgroups cl_intel_subgroups_char cl_intel_subgroups_short cl_intel_subgroups_long cl_intel_spirv_subgroups cl_intel_required_subgroup_size cl_intel_exec_by_local_thread cl_intel_vec_len_hint cl_intel_device_partition_by_names cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer
  Device Extensions with Version                  cl_khr_spirv_linkonce_odr                                        0x400000 (1.0.0)
Number of devices                                 1
  Device Name                                     NVIDIA GeForce GTX 1070 Ti
  Device Vendor                                   NVIDIA Corporation
  Device Vendor ID                                0x10de
  Device Version                                  OpenCL 3.0 CUDA
  Device UUID                                     51ab6f21-790f-c44c-43f0-0c089b0e253b
  Driver UUID                                     51ab6f21-790f-c44c-43f0-0c089b0e253b
  Valid Device LUID                               No
  Device LUID                                     6d69-637300000000
  Device Node Mask                                0
  Driver Version                                  495.44
  Device OpenCL C Version                         OpenCL C 1.2
  Device OpenCL C all versions                    OpenCL C                                                         0x400000 (1.0.0)
  Device OpenCL C features                        __opencl_c_fp64                                                  0xc00000 (3.0.0)
  Latest comfornace test passed                   v2021-02-01-00
  Device Type                                     GPU
  Device Topology (NV)                            PCI-E, 0000:03:00.0
  Max compute units                               19
  Max clock frequency                             1683MHz
  Compute Capability (NV)                         6.1
    Max number of sub-devices                     1
    Supported partition types                     None
  Max work item sizes                             1024x1024x64
  Max work group size                             1024
  Preferred work group size multiple (device)     32
  Preferred work group size multiple (kernel)     32
  Warp size (NV)                                  32
  Max sub-groups per work group                   0
    char                                                 1 / 1
    short                                                1 / 1
    int                                                  1 / 1
    long                                                 1 / 1
    half                                                 0 / 0        (n/a)
    float                                                1 / 1
    double                                               1 / 1        (cl_khr_fp64)
    Denormals                                     Yes
    Round to zero                                 Yes
    Correctly-rounded divide and sqrt operations  Yes
    Denormals                                     Yes
    Round to zero                                 Yes
  Global memory size                              8478654464 (7.896GiB)
  Max memory allocation                           2119663616 (1.974GiB)
  Unified memory for Host and Device              No
  Integrated memory (NV)                          No
    Fine-grained buffer sharing                   No
    Fine-grained system sharing                   No
    Atomics                                       No
  Alignment of base address                       4096 bits (512 bytes)
    SVM                                           0 bytes
    Global                                        0 bytes
    Local                                         0 bytes
  Atomic memory capabilities                      relaxed, work-group scope
  Atomic fence capabilities                       relaxed, acquire/release, work-group scope
  Max size for global variable                    0
  Preferred total size of global vars             0
  Global Memory cache size                        933888 (912KiB)
  Global Memory cache line size                   128 bytes
  Image support                                   Yes
    Max number of samplers per kernel             32
    Max size for 1D images from buffer            268435456 pixels
    Max 2D image size                             16384x32768 pixels
    Max 3D image size                             16384x16384x16384 pixels
    Max number of read image args                 256
    Max number of write image args                16
    Max number of read/write image args           0
  Pipe support                                    No
  Max number of pipe args                         0
  Max active pipe reservations                    0
  Max pipe packet size                            0
  Local memory type                               Local
  Local memory size                               49152 (48KiB)
  Registers per block (NV)                        65536
  Max number of constant args                     9
  Max constant buffer size                        65536 (64KiB)
  Generic address space support                   No
  Max size of kernel argument                     4352 (4.25KiB)
    Profiling                                     Yes
  Device enqueue capabilities                     (n/a)
    Out-of-order execution                        No
    Profiling                                     No
    Preferred size                                0
    Max size                                      0
  Max queues on device                            0
  Max events on device                            0
  Profiling timer resolution                      1000ns
    Run native kernels                            No
    Non-uniform work-groups                       No
    Work-group collective functions               No
    Kernel execution timeout (NV)                 No
  Concurrent copy and kernel execution (NV)       Yes
    Number of async copy engines                  2
    IL version                                    (n/a)
    ILs with version                              <printDeviceInfo:186: get CL_DEVICE_ILS_WITH_VERSION : error -30>
  Built-in kernels with version                   <printDeviceInfo:190: get CL_DEVICE_BUILT_IN_KERNELS_WITH_VERSION : error -30>
  Device Extensions                               cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info
  Device Extensions with Version                  cl_khr_global_int32_base_atomics                                 0x400000 (1.0.0)
strace clinfo (see the attached file esee.log)
viewing you log, have the same output like me (the last part, talking about NULL platform behavior)
so maybe is the output in a normal execution
greetings
NoorjahanSk_Intel
Could you please confirm whether your issue is resolved? If yes, can we go ahead and close this thread?
Thanks & Regards,
Noorjahan.
sl1pkn07
if you can confirm that message os correct behavoir, then yes
greetings
NoorjahanSk_Intel
We are working on your issue. We will get back to you soon.
Thanks & Regards,
Noorjahan.
Alexei_K_Intel
>> oneAPI suit also complains about libirml.so library
libirml.so is a special purpose library that is used only with tbb4py package. Regular oneTBB and Intel OpenCL runtimes do not require this library. Pay attention that strace does not show errors but only logs return statuses of particular system function. I.e. the fact that libirml.so is not found is not a error, it is expected behavior when oneTBB runtime uses dlopen to query if libirml.so present or not.
DMITRY_T_Intel
I think this issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Thanks!
