I was using matlab 2013b and Matlab Compiler Runtime 2013b to make a standalone program. Matlab can successfully generate an executable but when I run it I got "The procedure entry point ?deallocate_via_handler_v3@internal@tbb@@YAXPAX@Z could not be located in the dynamic link library tbb.dll." I tried different codes and got the same error. My operating system is Windows 7 professional. I tried both 32 bit and 64 bit matlab and MCR but none of them worked out.
I contacted Matlab technicians and was told that "There are known problems/errors/bugs/issues with tbb.DLL and the MATLAB R2013b compiler, at least for the Image Acquisition Toolbox". What can I do to fix this problem?
Thanks in advance.
what is the file version of tbb.dll? it looks the program found older version of tbb.dll than needed.
--Vladimir
Thanks for the message Vladimir. I checked the tbb.dll file in the system32 folder, and the version is 2.1.2009.325. Looks like it's the 2009 version. Is there a newer version I can use?
you can try even the latest version 4.2 update 2 https://www.threadingbuildingblocks.org/download#stable-releases
we are trying to keep backward compatibility starting version 2.1.
--Vladimir
Sorry for the naïve question but I'm really new to this... how should I install this?
I tried to put the tbb.dll in the system32 folder. I renamed the original one I have so I assume the new one is working now? I tried tbb.dll in different vc9-11 folders, both 32 and 64-bit, but I always get the same error.
