I know it looks strange, but in the use case of ressources management (the tbb::flow::buffer_node holds pre-allocated ressources), it would be usefull to capture multiple in a join.
Example of the strange thing I tried to do and is not working is below. Any idea how to implement something like this without having to create multiple buffers?
#include <iostream> #include "tbb/flow_graph.h" using namespace std; using namespace tbb; using namespace tbb::flow; int main(int argc, char *argv[]) { graph g; buffer_node<int> buff1(g); for (int i = 0; i < 3; ++i) { buff1.try_put(i); } using input_t = tuple<int, int, int>; using joinNode_t = join_node< input_t >; using funcNode_t = function_node< input_t, int>; joinNode_t j(g); funcNode_t f1(g, 0, [](input_t i)->int { cout << "f1[" << get<0>(i) << "," << get<1>(i) << "," << get<2>(i) << "]\n"; return get<0>(i)+get<1>(i)+get<2>(i); }); // this is not working make_edge(buff1, input_port<0>(j)); make_edge(buff1, input_port<1>(j)); make_edge(buff1, input_port<2>(j)); make_edge(j, f1); g.wait_for_all(); }
Hi, Marc,
There are two things I notice about your program:
- As soon as you attach two nodes together, a task is spawned to execute the first node. So when you attach a buffer_node to the input of a queueing join_node, a task will forward all messages in the buffer to the port you attached to. The buffer may be empty by the time you attach the second port of the join_node.
- There are two different forwarding policies in nodes: broadcast-push and single-push. Most nodes broadcast their messages, but buffering nodes will forward each message to only one successor. So even if the timing of attaching the buffer_node to the join_node weren't a problem, you would not get the result you expect.
Remember that queueing join_nodes buffer their input until a successor is available, so, depending on your needs, you can replace the buffer_node with a broadcast_node:
broadcast_node<int> broad1(g); // change to broadcast here using input_t = tuple<int, int, int>; using joinNode_t = join_node< input_t >; using funcNode_t = function_node< input_t, int>; joinNode_t j(g); funcNode_t f1(g, 0, [](input_t i)->int { cout << "f1[" << get<0>(i) << "," << get<1>(i) << "," << get<2>(i) << "]\n"; return get<0>(i)+get<1>(i)+get<2>(i); }); // build the graph before putting any messages to it make_edge(broad1, input_port<0>(j)); make_edge(broad1, input_port<1>(j)); make_edge(broad1, input_port<2>(j)); make_edge(j, f1); // now put the messages, which will be forwarded to all inputs of the join_node for (int i = 0; i < 3; ++i) { broad1.try_put(i); } g.wait_for_all();
Remember the queueing join_node does not try to match any aspect of its inputs, it just puts the first message it received at each port together into a tuple and forwards it (if possible) to its successor. If you are managing resources in a flow::graph, you might look at Mike Voss's feature recognition blog. (The example uses a tag-matching join_node to manage the use of a finite set of buffers.)
Sorry, the "(round-robin)" part of the post above was a placeholder until I found the "official" name we have for the message-forwarding policy of buffering nodes. You can look at this section of the TBB User Guide for a bit of an explanation of it.
