Hi there!
In the transition from TBB "4.1" to "4.1 Update 1" something seems to have gone wrong.
Attached is a simple test case (inspired by http://software.intel.com/en-us/blogs/2011/09/14/how-to-make-a-pipeline-with-an-intel-threading-building-blocks-flow-graph).
The program is supposed to generate 100 numbers, let them be squared, and then print the square. The limiter node is set to an arbitrary limit of 7, to limit the number of numbers that are processed in parallel.
I use Visual Studio 2012 to compile this. With TBB V4.1 (20120718) and earlier versions, everything works fine: 100 numbers and their squares are printed. With TBB V4.1 Update 1 (20121003) the program stops after 8 numbers or so. It just terminates. This can be influenced by adjusting the limiter_node limit (7 in the example).
I have traced the problem back to the include file tbb/flow_graph.h: I can use both versions of the TBB DLL, but only the 20120718 version of tbb/flow_graph.h will produce the desired result.
For me, this is a showstopper. I have no idea how to work around this. Hope I've provided enough info! Thanks for any help or input on this - maybe I've just misunderstood the whole concept of a limiter_node :-)
Michael
