permutation_range(n)
ARCH_R_Intel
Here's a interesting mathematical question: Is there a way to define a range object that lets us write a parallel_for that iterates over permutations of a set of N objects? Better yet, can it be done so that subranges are always in lexicographic order?
Here's how it might be used. The parallel_for invocation might look something like:
parallel_for( perm_range(N), Body() );
and Body::operator() might look something like:
void Body::operator()( const perm_range& r ) {
permutation p = r.begin();
while( p!=r.end() ) {
...process the permutation...
...get the next permutation...
std::next_permutation( p.begin(), p.end() );
For example, for N=3, we would want the permutations:
0 1 2
0 2 1
1 0 2
1 2 0
2 0 1
2 1 0
to be generated. The hard part is figuring out how to divide a permutation range into two roughly equal subranges.
- Arch
P.S. TBB does support recursive parallelism, so it's straightforward to write a recursive program that does permutations in parallel, using a parallel_for at each recursion level. I can post that code if anyone cares.
huil
The lexicographic ranking and unranking of permutations might be useful for this problem, but could be quite costly. They perform a 1-on-1 mapping between a permutation of integers {0,1,...,(n-1)} and an integer within [0,n!). The algorithms can be found in the book "Combinatorial algorithms" by Donald L. Kreher and Douglas R. Stinson. If you're interested, I can post my implementation here.
ARCH_R_Intel
I came up with a reasonably straightforward and efficient solution a while back, but didn't have time to post it until now. See code below. It still has printfs in it that are inappropriate for parallel execution, but I left them there to show where the permutations appear.
- Arch
// permute.cpp : Defines the entry point for the console application.
// Program that shows how to write a TBB-style recursive range for permutations.
// Author: Arch D. Robison
// Date: 9/18/2007
#include
#include
#include "tbb/parallel_for.h"
#include "tbb/task_scheduler_init.h"
//! Recursively divisible set of permutations of N objects of type T.
/** Internally, it represents all permutations x of a such that:
 x==a for all k
 x[position]is some a for k in [i,j)
 x is some a for k in [position,N]
 Be sure to use the default simple_partitioner, not auto_partitioner, because the range cannot be iterated
 over unless is_divisible() returns true.
template<typename T, size_t N>
class permutation_range {
 unsigned position;
 //! When position reaches limit, the set of permutations is no longer considered divisible.
 const unsigned limit;
 unsigned i, j;
 T a;
 //! Check that internal state is c
orrect.
 bool assert_okay() {
 assert( i
 assert( j<=N );
 assert( position<=i );
 assert( position<=limit );
 for( unsigned k=0; k
 assert( a
 for( unsigned n=0; n
 assert( n==k || a!=a );
 return true;
 void normalize_if_leaf() {
 if( position==limit-1 && i+1==j ) {
 std::rotate(&a[position],a+i, a+i+1);
 assert( assert_okay() );
public:
 bool empty() const {
 return position==N;
 bool is_divisible() const {
 return position+1
 //! Construct initial permutation
 permutation_range( const T x, unsigned grainsize ) :
 position(0),
 limit(N
 i(0),
 j(grainsize
 std::copy( x, x+N, a );
 //! Splitting constructor
 permutation_range( permutation_range& r, tbb::split ) : limit(r.limit) {
 assert( r.assert_okay() );
 assert( r.is_divisible() );
 if( r.i+1==r.j ) {
 assert(r.j==r.i+1);
 std::rotate(&r.a[r.position],r.a+r.i, r.a+r.i+1);
 r.i = ++r.position;
 r.j = N;
 std::copy( r.a, r.a+N, a );
 int m = (r.j-r.i)/2;
 assert(m>0);
 j = r.j;
 i = r.j = r.i+m;
 position = r.position;
 normalize_if_leaf();
 r.normalize_if_leaf();
 //! Set x[] to first permutation in this range.
 void get_first_subpermutation( T x ) const {
 assert(!is_divisible());
 std::copy( a, a+N, x );
 //! Advance x[] to the next permutation in this range. Returns true unless next permutation was a wrap.
 bool next_subpermutation( T x ) const {
 return std::next_permutation( x+limit, x+N );
const int N = 5;
struct Body {
 void operator()( const permutation_range<int,N>& r ) const {
 int a;
 r.get_first_subpermutation(a);
 // Process all permutations in the subrange
 printf("	slice
 do {
 // Operations on a given permutation
 printf("		");
 for( int k=0; k
 printf("%d ",a);
&n
bsp; printf("
 // Get the next permutation
 } while( r.next_subpermutation( a ) );
int main() {
 const int N = 5;
 tbb::task_scheduler_init init(1);
 int a;
 a = k;
 // Try different grain sizes
 for( int g=1; g<=N; ++g ) {
 printf("With grain size=%d
",g);
 tbb::parallel_for( permutation_range<int,N>(a,g), Body() );
 return 0;
