Assertion OneTimeInitializationsDone failed on line 774 of file ../../src/tbb/task.cpp
Detailed description: thread did not activate a task_scheduler_init object?
Aborted
I'm using following flags (gcc 4.1):
-pg -O2 -Wall -funroll-all-loops -Winline -finline-functions -march=opteron -lnuma -ltbbmalloc_debug -ltbb_debug -lgoto_opteronp-r1.10
Can somebody help?
Thanks!
Intel Threading Building Blocks uses a thread pool to execute the tasks and has other initialization tasks that need to be performed. The way this is done in TBB is through the creation of a task_scheduler_init object whose lifetime spans the duration in the program where TBB is employed. The error listed above indicates that no task_scheduler_init object was created prior to the first TBB task initiation request. If you add something like
main(int argc, char **argv) {
tbb::task_scheduler_init init;
to your program, the error you're seeing SHOULD go away. (You'll need to add an "#include
And not after that. I dont have any other commands that calls the TBB yet.
The #include... line is there too.
#include "Matrix.hh"
#include "qr_decomp.hh"
#include "morton.h"
#include "time_mes.hh"
#include fstream //changed due to html filter
#include "tbb/task_scheduler_init.h"
using namespace std;
using namespace tbb;
int main ( int argc, char** argv )
int M=2048;
int N=2048;
int bs=32;
double beta1
double *A;
double operations;
double *testM;
double *testV;
task_scheduler_init init; //error here
...my_functions();
return 0;
Thanks for reporting the problem. I think I know what is the root cause. Check if changing the order of TBB libraries in the command line fixes the issue for you, i.e. use -ltbb_debug first and -ltbbmalloc_debug second. If you do not use scalable memory allocator directly, you might consider completely removing tbbmalloc from compilation command; internally, TBB will still use tbbmalloc via dlopen.
And of course we will fix the issue in one of subsequent developer updates. Thanks again!
Thank you!
Now it works.
![](/skins/images/8B6E2C8F64F54CBD7F7262AA46F575DA/responsive_peak/images/icon_anonymous_message.png)
