I have been using tbb::fixed_pool as an allocator for "small objects". When the fixed_pool is full ( returns NULL) , I default to a normal dynamic allocator.
I have found, however, that performance of tbb::fixed_pool drops very dramatically when the pool is "full". It appears that rather than having a simple internal flag to indicate this state (no more space to allocate), the fixed_pool allocator must be doing a 'lot of work' to decide it cannot allocate.
Forgot to mention , it's TBB 4.2
I am not exactly sure what you mean. Perhaps I am missing the point, I assumed a fixed pool had a 'fixed' size. I had found that using a fixed_pool for small allocations improved performance overall but what I also found when testing was that in the 'edge' case where the pool is ( or nearly) completely full performance drops off very badly (10x at least)
static char buf[POOL_SIZE];
static tbb::fixed_pool my_pool(buf, POOL_SIZE);
if(size<=POOL_ALLOCATION_MIN){ ptr=my_pool.malloc( size); // fixed pool full! if(ptr==NULL){ ptr=::scalable_malloc( size); } }else{ ptr=::scalable_malloc( size); } return ptr;
Is performance of growable memory pool too low on you workload? In you approach, I see a problem with ownership detection during free, i.e. during release we must find is ptr belong to pool or scalable_malloc. It's solvable but not possibly cheap.
tbb::memory_pool<tbb::scalable_allocator<char> > pool; void *ptr = pool.malloc(12); pool.free(ptr);
I would need to experiment with tbb::memory_pool<tbb::scalable_allocator<
char
> > pool
before making a comment.
Regarding ownership detection during free. If 'p' has been allocated from the fixed_pool ('buf') then it is easy to detect. For example.
if(p>=buf && p<(buf+POOL_SIZE) ){ my_pool.free(p); }else{ ::scalable_free(p); }
My experiments with tbb::memory_pool<tbb::scalable_allocator<char> > show that it shows performance degradation over using the fixed_pool
This is interesting. So far, I see 2 possible reasons for tbb::memory_pool<tbb::scalable_allocator<char> > regression over fixed_pool: premature memory releasing and small initial buffer in scalable_allocator solution. 1st can be checked by switching to special pool that never release memory till destruction.
#include <tbb/scalable_allocator.h> static void *getMem(intptr_t /*pool_id*/, size_t &bytes) { return scalable_malloc(bytes); } static int putMem(intptr_t /*pool_id*/, void *ptr, size_t /*bytes*/) { scalable_free(ptr); return 0; } rml::MemoryPool *pool; rml::MemPoolPolicy pol(getMem, putMem, /*granularity=*/0, /*fixedPool=*/0, /*keepAllMemory=*/true); rml::pool_create_v1(0, &pol, &pool); void *p1 = rml::pool_malloc(pool, 32); rml::pool_free(pool, p1); pool_destroy(pool);
And second by switching to pool that has user-controlled initial buffer.
#include <tbb/scalable_allocator.h> #include <tbb/atomic.h> static const size_t POOL_SIZE = 10*1024*1024; static tbb::atomic<bool> start_buf_used; static char start_buf[POOL_SIZE]; static void *getMem(intptr_t /*pool_id*/, size_t &bytes) { if (0 == start_buf_used.compare_and_swap(1, 0)) { bytes = POOL_SIZE; return start_buf; } return scalable_malloc(bytes); } static int putMem(intptr_t /*pool_id*/, void *ptr, size_t /*bytes*/) { if (ptr == start_buf) start_buf_used = 0; else scalable_free(ptr); return 0; } rml::MemoryPool *pool; rml::MemPoolPolicy pol(getMem, putMem); rml::pool_create_v1(0, &pol, &pool); void *p1 = rml::pool_malloc(pool, 32); rml::pool_free(pool, p1); pool_destroy(pool);
I am not so worried about the 'slightly' slower speed of the dynamic vs. fixed_pool. It was simply unexpected that fixed_pool would have such chronically bad performance when full. So its just a heads-up on that one. Otherwise the scalable allocators are simply extremely fast compared anything else I have tried. You might want to suggest to the Intel MKL team they use the TBB alocators as the MKL allocators are much slower!
