Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3089 Discussions
802.1 Provisioning Issue
Hi
I've run into an issue with AMT provisioning on a Lenovo M91p running firmware / MEI 7.x
Running the provision from SCCM with SP2 installed. I can fully provision a device without using the 802.1x and wireless options on the OOBM settings, but when configuring the 802.1x and wireless options I get the following information in the log:
Error: Failed to add a new Trusted root certificate,Device does not support the certificate format.
Error: Failed to add a new Trusted root certificate,return value:2063.
Error: Failed to finish critical setup and configuration step. (AMTWSManUtilities::AddCertificate)
Warning: CSMSAMTProvTask::StartProvision Fail to call SetWirelessServerCertificate
Begin to set Wired 8021x Profile...
No Trust Root Certificate
The wired profile is invaid. Skip adding...
I have both imported the .CER and tried pulling directly from the issuing CA - but still get the same issue.
Are there any specific settings related to the Trusted Root Cert? Do I need the entire Cert chain as well?
We use a CA with issuing CA's on 2008.
Ian
I've worked out the problem, we need to use a shorter Root Cert. Ours is currently 4096, wheras we should be using a key length of no greater than 2048 for AMT.
I didnt run into the issue up to now as we use a Comodo Cert for provisioning.
The give away was:
Solution:
Build a second CA with a Root key of 2048 in length. and issue this for purposes of 802.1x.
