Let me start by saying I'm a complete amateur when it comes to PC's. Here's what my issues with AMT are:
1. My computer became slower and slower. After an analisys with a software called MTB (taken from bleepingcomputer.com), I discovered that I have many errors involving AMT. You can see all of them in the attached file called "MTB". Also to help you, I used a software called Speccy, which gives you a full view of my PC. The report is here: http://speccy.piriform.com/results/08Dcu2Zcwl3tSIRLOrURhwo http://speccy.piriform.com/results/08Dcu2Zcwl3tSIRLOrURhwo
What can I do about those errors? Are they the ones slowing my computer?
2. since this is my personal PC, would it help if I disable the AMT feature? I found a guide here http://smallbusiness.chron.com/disable-intel-active-management-29020.html How to Disable Intel Active Management | Chron.com . Is the process described correctly?
Thank you in advance for all the help.
Later edit: meanwhile, I have also used a software called "Cristal Disk Info" which reported that my disk is in good condition.
I would not necessarily believe those 3rd party utilities.
However, regarding AMT, it is best to ask your question here: /community/tech/vproexpert Intel® vPro™ Expert Center
Doc
Thanks for your reply. I saw that Expert Center, but I thought that It's only for prefessionals. I'll move the question there
Thanks Al Hill for helping with this.
Ivan.
![](/skins/images/3CECF0550DB8BF54496C114A1FF06FE9/responsive_peak/images/icon_anonymous_message.png)
