Intel vPro® Platform
3053 Discussions
AMT device is "not provisioned" or "detected" - sccm sp2
I need your help.
We're trying to provisioned the AMT device 5.1.10 (HP) with SCCM SP2 R2, but the machine is not provisioned. AMT Status show is "Not provisioned" or "Detected".
- AD / DNS / DHCP/ Certificate Authority (Internal CA) - srvad
- SRVSCCM SP2 R2 - srvsccm
- The certificate hash of client (vpro machine) was configured in Mbex
The oob role is configured follows the technet steps.
The amtopmgr and oobmgmt is attachment.
tks a lot,
Salem_W_Intel1
Hi!
Most likely the error messages take place because the AMT portion of the system has not been configured. I recommend referring to the helpful User Guide found here:
http://communities.intel.com/docs/DOC-2658
Hi Mara,
Make sure you check the HP site for the latest AMT firmware release for your system.
As a test, try to manually move the system you are trying to provision into an SCCM collection that has auto-provision enabled.
Another thing to try is to run the activator utility on the machines you are trying to provison:
http://software.intel.com/en-us/articles/intel-vpro-technology-activator-utility/ http://software.intel.com/en-us/articles/intel-vpro-technology-activator-utility/
then try to perform a discover on the system.
syntax would be:
activator.exe /s https://fqdn_of_your_sccm_server/ https://fqdn_of_your_sccm_server/ /h /c
let me know if that helped!
