Intel vPro® Platform
3072 Discussions
SCCM OOB console issue on remote SCCM console
We successfully provision AMT machine with SCCM and can use SCCM OOB console to manage AMT machine on SCCM server. But we found that we can't use OOB console on remote SCCM console to connect same AMT machine. The status indicate connecting with long time and then disconnted. What's problem on remote SCCM console? Do we need do a special configuration for remote OOB console on remote SCCM console? But strange thing is that I can remote power-on/off/restart AMT machine on remote SCCM console. Of course, it's not done in OOB console.
Below is error message from \AdminUI\AdminUILog\Oobconsole.log
denied:2008-9-11 15:23:08 :System.Management.ManagementException\r\n找不到 \r\n at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementObject.Initialize(Boolean getObject)
at System.Management.ManagementBaseObject.get_wbemObject()
at System.Management.PropertyData.RefreshPropertyInfo()
at System.Management.PropertyDataCollection.get_Item(String propertyName)
at System.Management.ManagementBaseObject.GetPropertyValue(String propertyName)
at System.Management.ManagementBaseObject.get_Item(String propertyName)
at Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlConnectionManager.RefreshSiteControlFile(ManagementBaseObject managementObject)\r\nManagementException details:
instance of __ExtendedStatus
Operation = "GetObject";
ParameterInfo = "SMS_SCI_Component.FileType=2,ItemName=\"SMS_AMT_PROXY_COMPONENT|SH-SCCM\",ItemType=\"Component\",SiteCode=\"PSA\"";
ProviderName = "WinMgmt";
\r\n
6 [2008-9-11 15:23:08] :Failed to query default IDER path
6 [2008-9-11 15:23:08] :Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlQueryException\r\nConfigMgr 提供程序报告了一个错误。\r\n at Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlConnectionManager.RefreshSiteControlFile(ManagementBaseObject managementObject)
at Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlConnectionManager.GetInstance(String objectPath)
at Microsoft.ConfigurationManagement.AdminConsole.OobConsole.Utilities.QueryManager.GetDefaultPath(String& defaultPath)\r\nConfigMgr 错误对象:
错误代码:
NotFound
\r\nSystem.Management.ManagementException\r\n找不到 \r\n at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
\r\n
6 [2008-9-11 15:23:08] :GetAMTPowerState fail with result:0x80072EE9
6 [2008-9-11 15:23:18] :GetAMTPowerState fail with result:0x80072EE9
6 [2008-9-11 15:23:28] :GetAMTPowerState fail with result:0x80072EE9
6 [2008-9-11 15:23:47] :System.Management.ManagementException\r\n找不到 \r\n at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
\r\n
6 [2008-9-11 15:23:47] :Failed to query default IDER path
6 [2008-9-11 15:23:47] :Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlQueryException\r\nConfigMgr 提供程序报告了一个错误。\r\n at Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlConnectionManager.RefreshSiteControlFile(ManagementBaseObject managementObject)
错误代码:
NotFound
ParameterInfo = "SMS_SCI_Component.FileType=2,ItemName=\"SMS_AMT_PROXY_COMPONENT|SH-SCCM...
Does the OOB console on Remote Console means the OOB console which running on different machine with the SCCM server? Did you install the AMT's root certificate and the provision certificate on this remote machine?
-Jen
yes, OOB console was runs from remote SCCM console. We also installed SCCM root CA on remote PC.
bill
Hi Bill,
Make sure you have the entire chain of certs installed in the local machine TRUSTED ROOT store of your remote SCCM console.
