Intel vPro® Platform
3051 Discussions
AMT ip release/renew
JRüeg
Dear community
We use Intel EMA to configure our endpoints to admin control mode. When the notebooks are shut down, AMT will get an ip from a dhcp server and connect to a network which allows traffic to the swarm server without authenticating on the network (without 802.1x). The endpoints connect with CIRA and can be started remotely from EMA web application.
When Windows starts up, Windows will authenticate on the network using a ceritificate and the new ip address will be from a differnt network.
For quite some time AMT continues to send ARP-requests with the old sender ip address, which poses a problem for our network configuration. In Windows, the old ip address isn't visible. Windows only knows of the new address from the authenticated network.
Is there a way/tool/command to make AMT forget the (old) ip address and use the new one exclusivly? Or timers to set to shorter values to make this happen faster automatically?
Using ipconfig /release and ipconfig /renew in Windows does work, but causes a short network disruption for the operating system and applications. We would prefer only to target the AMT firmware.
Now, I know we could configure AMT to use network authentication as well, but this has caused problems in the past and we prefer a solution with an unauthenicated network, since we need that anyway.
Our EMA server is on version 1.12.2.0 but could be updated if need be. The endpoints are on firmware 16.1.35.2557.
vish1
Hello JRüeg,
Greetings!!
There is currently no supported command or tool to force only the AMT firmware to immediately release or renew its DHCP address without affecting the OS. The recommended approach is to enable AMT-host IP synchronization for wired interfaces, but even then, changes may not be immediate and may not resolve all cross-network scenarios. Otherwise, you must rely on DHCP lease expiry or manual reprovisioning via EMA.
Kindly find the reference link for the statement above-
https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments%2Fconfiguringtheintelamtipaddress.htm
https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments%2Fautomaticsynchronizationofipaddresses.htm
https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments%2Fsetipv4dhcpandstaticipaddressmodes.htm
To update the ME firmware to the latest version, please refer to the link below:
https://www.intel.com/content/www/us/en/download/682431/intel-management-engine-drivers-for-windows-10-and-windows-11.html
Intel® Wireless Wi-Fi Drivers for Windows® 10 and Windows 11-
https://www.intel.com/content/www/us/en/download/19351/intel-wireless-wi-fi-drivers-for-windows-10-and-windows-11.html
Vishal Shet P
intel.com/vpro
vish1
Hello JRüeg,
Greetings!!
To proceed with the configuration of your EMA environment, could you please provide the following details:
  1. SQL Server version
  2. Operating System version of the server
  3. Location of the SQL Server and EMA Server (Physical or Virtual)
  4. Will the SQL Server and EMA Server be hosted on the same machine?
  5. Authentication mode to be used: Local, Azure AD, or Windows AD
  6. Number of endpoints to be provisioned
  7. Are the endpoints and the EMA server located in the same network, or in different networks?
Vishal Shet P
intel.com/vpro
JRüeg
Dear Vishal
Our EMA environement is already configured and working.
We have trouble with the behaviour of the clients because we use network authentication in Windows but not in AMT, so the clients are in different subnets when windows is started but there is still some communication from AMT on the network AMT uses when Windows is off.
I am asking for a way to release/renew the AMT ip on the client after Windows booted.
Not sure if this will provide any relevant infos, but here the answers to your questions:
    Microsoft SQL Server 2022
    All servers are Windows Server 2022
    All virtual servers, in differnet subnets with the requiered ports opened on the firewall
    No it is on different machines
    Windows AD
    We currently have 6800 endpoints provisioned
    Different networks, with the required ports opened
vish1
Hello JRüeg,
Greetings!!
This is the follow-up regarding the issue you reported to us.
We wanted to inquire whether you had the opportunity to review our previous information we provided.
Vishal Shet P
vish1
Hello JRüeg,
Greetings!!
Vishal Shet P
intel.com/vpro
JRüeg
Thank you for confirming there is no way to achive a faster / immediate ip release on the amt device after the windows ip changed.
vish1
Hello JRüeg,
Greetings!!
If further assistance is necessary, do not hesitate to reply.
Vishal Shet P
intel.com/vpro
