Intel vPro® Platform
3046 Discussions
AMT meets bootloader pre-boot authentification requirements
ASchw7
I'm struggling with the following problem for several days now.
The scenario is as follows: I have a server with a bootloader which requires me to enter a password before booting (This bootloader can not be configured to use a serial port for communication). I have to administer the server from remote so I need a technique to enter this password from remote and (this is important) do this automatically by a script.
I'm now thinking if the Intel AMT functionality would suit my needs (if so I would buy the appropriate hardware)
-As I understand it, I will not be able to use the Serial Over Lan (SOL) functionality, because the bootloader wouldn't work with SOL. Is this correct?
-So an alternative would be the KVM functionality. But would it be possible to just send the password via script with the KVM? (As script here I understand everything which enables me to send the password automatically without typing it in manually with the keyboard)
-I also saw the Intel AMT SDK. I'm able to program c++ and c# using this SDK, if it helps me with my problem.
So this are the three main points I found, but I still don't know if one of these can solve my problem.
Thank you for any help,
Alex
Alan_A_Intel
Alex,
It really depends on how the bootloader functions. It might be possible to use Serial Over LAN, as long as the bootloader doesn't switch to a graphical mode or take control of the serial ports.
KVM will work, but it will be a more involved process than using SOL.
I would suggest asking your question in the Business Client Developer Community, as they will be able to give you a more detailed answer.
http://software.intel.com/en-us/business-client http://software.intel.com/en-us/business-client
