Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3090 Discussions
About Server Settings
M_T11
I believe you can enter the detailed settings for the 5 servers in the EMA management console. (Captured below)
I assume that these settings will be defaulted to the settings used when the EMA servers were built. Are the default settings basically the manufacturer's (Intel's) recommended values?
VijayN_Intel
Hello M_T11,
Greetings!
Thank you for posting in the Intel Communities.
The Intel Endpoint Management Assistant (Intel® EMA) allows administrators to configure detailed settings for multiple servers through its management console. When these servers are initially set up, they typically use default settings that align with our recommended values for optimal performance and security.
To modify the settings of various component servers (e.g., Swarm Server, Ajax Server, etc.) within the Intel EMA server, follow these steps:
  • Navigate to the Server Settings tab via the Settings option in the left-hand navigation pane.
  • To adjust security settings, use the Security Settings tab. You can find a comprehensive list of security settings and their descriptions under Security Settings.
For detailed instructions, I recommend reviewing Section 6.1 in the Server Installation Guide, which you can access here:
Intel EMA Server Installation and Maintenance Guide
Please don't hesitate to reach out if you have further questions.
Vijay N.
Intel Support Team
VijayN_Intel
Hello M_T11,
Greetings!
Vijay N.
Intel Support Team
VijayN_Intel
Hello M_T11,
Greetings!!
I am following up on the case and wondering if I can help you with anything else. Look forward to your response.
Vijay N
VijayN_Intel
Hello M_T11,
Greetings!!
If further assistance is necessary, do not hesitate to reply.
Vijay N.
