Intel vPro® Platform
3079 Discussions
Access to the Intel® vPro™ Web UI with Active Directory User IDs
ÉGagn
My problem is:
When I attempt to log
on to the Intel AMT WebUI using a web browser,
the logon box prompts for a domain-based credential (domain\user with
associated password). The same credentials work correctly with VNC Viewer.
When I Deselect the IE option Enable Integrated Windows Authentication
I am able to log with the admin and the mebx password. I want use the
active directory for Web Ui authentication.
My computer settings:
Windows 8.1 and IE11
My SCSnsole
version 11
My amt version 9.1.20 intel
vpro
I look this kb http://support.microsoft.com/kb/908209 http://support.microsoft.com/kb/908209 but is a very old kb.
Some people can help me
please?
Eric
Dariusz_W_Intel
You need to add one of following registry keys on each Intel AMT console system :
For 32 Bit: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_INCLUDE_PORT_IN_SPN_KB908209\"iexplore.exe"=dword:00000001
For 64 Bit: HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_INCLUDE_PORT_IN_SPN_KB908209\"iexplore.exe"=dword:00000001
Use following command to add them:
REG ADD "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_INCLUDE_PORT_IN_SPN_KB908209" /v iexplore.exe /t REG_DWORD /d 00000001
REG ADD "HKLM\SOFTWARE\WOW6432Node\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_INCLUDE_PORT_IN_SPN_KB908209" /v iexplore.exe /t REG_DWORD /d 00000001
You have to use FQDN of vPro system when connecting to it (not just IP addess).
Remeber to not manually (or via AD scripts) alter or remove $iME AD computer objects in additional AD OU you created and used for Intel AMT Active Directory Integration in AMT profile!!!
Please see more explanation : https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments/usingactivedirectorytomanageintelamtdevices.htm https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments/usingactivedirectorytomanageintelamtdevices.htm and
http://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments/notesandlimitations.htm http://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments/notesandlimitations.htm
Dariusz Wittek
Intel EMEA | Biz Client Solution Architect
Dariusz_W_Intel
Dariusz Wittek
