Intel vPro® Platform
3055 Discussions
CIRA Not Connected with AMT 16
rduarte
All my AMT 16 devices go into "CIRA Not Connected" after some time. They work fine for hours but then they start showing "CIRA Not Connected", even though I can see traffic from them to EMA on port 8080.
All my AMT 14 and 12 devices work fine with the same EMA server and same AMT profile, in the same networks.
Any idea what can be the problem? Devices are DELL OptiPlex 7010.
Victor_G_Intel
Hello rduarte,
To analyze your situation, we will require the information below:
What EMA version are you currently having this issue with?
How many AMT 16 devices you are having this issue with?
In total how many endpoints does your deployment have?
Are these affected endpoints fully updated (BIOS, OS and drivers)?
Do you have a single server or a multi server environment for EMA?
Is EMA installed directly on a server or did you install it in a VM? Also please share exactly hwat OS build is being used for the EMA server.
Do you use Client control mode (CCM) or admin control mode (ACM)?
Please share with us with the following logs:
EMA logs from Server:
[System drive]\Program File(x86)\Intel\Platform Manager\EmaLogs
ECT logs: We will require one from an affected endpoint and another from a good known fully provisioned endpoint if possible):
Intel® EMA Configuration Tool
https://www.intel.com/content/www/us/en/download/19805/intel-endpoint-management-assistant-configuration-tool-intel-ema-configuration-tool.html
Installation:
Double-click the .msi file and follow the prompts.
Run:
a- Open a command prompt as administrator.
b- Navigate to the installation folder (default C:\Program Files (x86)\Intel\EMAConfigTool).
c- Run the command: EMAConfigTool.exe -filename XXXX –verbose
Victor G.
Intel Technical Support Technician
rduarte
Hi Victor,
Answers:
1.12.2.0
20
70
Yes
Single Server (but installed to allow multiple servers)
VM running Windows Server 2019
ACM
Where can I upload the logs?
rduarte
Intel ME version is 16.1.30.2330
Victor_G_Intel
Hello rduarte,
Thank you for your responses.
You can use the Drag and drop here or browse files to attach option at the bottom of the page when you are responding, you will have to make sure you are properly logged into the forum.
Victor G.
Victor_G_Intel
Hello rduarte,
We hope this message finds you well.
Do you have any updates for this thread?
Victor G.
Victor_G_Intel
Hi rduarte,
We have not heard back from you.
Victor G.
