Intel vPro® Platform
3058 Discussions
Can I installed AMT reflector client and server on the same AMT machine?
Per my understanding, the refecltor server can installed with client on the same AMT machine. But when i did this, the server cannt be started. the error messsage are as following:
_________________________________________________________________________________________________________________
ystem.Net.Sockets.SocketException: Only one usage of each socket address (protocol/network address/port) is normally permitted
at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Bind(EndPoint localEP)
at System.Net.Sockets.TcpListener.Start(Int32 backlog)
at System.Net.Sockets.TcpListener.Start()
at Intel_AMT_Reflector_Server.MainForm.startButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
0.9.866.1
Thanks very much!
-Jen
Jen,
I'm not familiar with the AMT reflector ... which tool is this?
From what I can tell, from the .NET exception information you posted, it looks like there is a conflict over TCP ports, when the Socket object is attempting to bind to the port.
Is there a way to specify which port each program runs on? You might want to try defining an alternate port for one or the other.
Trevor Sullivan
Systems Engineer
OfficeMax Corporation
Jen,
There is a video here that I think will help you out:
http://communities.intel.com/community/openportit/vproexpert/activation/blog/2008/06/12/intel-amt-reflector-new-release-posted-wvideo-tutorial-too;jsessionid=BB7BCE258989BAB99D8852DE9B7D924E http://communities.intel.com/community/openportit/vproexpert/activation/blog/2008/06/12/intel-amt-reflector-new-release-posted-wvideo-tutorial-too;jsessionid=BB7BCE258989BAB99D8852DE9B7D924E
Tim Duncan is talking about how to change the port that the reflector server is running on.
In the server console, remove the 4 default port redirections, and add 4 new ones, such as:
17992 --> 16992
17993 --> 16993
17994 --> 16994
17995 --> 16995
If the server console is running on an AMT-enabled system, then port conflicts could occur by using the default port mappings.
Trevor Sullivan
Systems Engineer
