Intel vPro® Platform
3072 Discussions
DP35DP Motherboard spdif connection
I have the above motherboard along with a KFA2 Nvidia Geforce 9600GT 1Gb Video Card with HDMI out. In order to use the audio side of the HDMI, I must connect a two wire spdif line to the card and to the spdif connectore on the motherboard. The problem is that I can find no two pin spdif audio connector on the motherboard. My only spdif choice is a nine pin audio connector that I don't want to just try open pins with. Can anyone advise me the correct pins to use from the nine pin connector that will allow audio to be fed to the hdmi out on the video card?
Jeff
Hi Jeff, I have the same problem, did you find a out how to connect the spdif cable to the board?
Ariel.
Hi there,
Apparently, i was checking whether there is any spdif connector on the board DP35DP, the result was "No i cannot find any".
I have checked on these boards:
DG31GL, DG31PR, DG35EC, DX38BT,
There is a straight SP/DIF to SP/DIF cable would provide the "pass through" of audio to the graphics card.
Hope this helps.
Aryan
Hi, I have the same issue here
so is there a way to convert HD audio link to S/PDIF 3 pin connector???
semi
