Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3088 Discussions
Can't retrieve MEBx password using API
tech_tc
Hi All
Fairly new to this product and having some password reset issues.
I could'nt change the default 'admin' password as is wouldn't accept any other passwords after entering the default.
So decided to retrieve the MEBx passord using API. I can find the endpoint ID and the syntax seems straight forward to obtain password, but i get a 404 error when i run the GET command.
This is what i have so far.
https://my_ema_server/api/latest/amtCredentials/my_endpoint_ID/mebx
My user is a Tenant Administrator.
Any help would e appreciated.
tech_tc
Hi Victor G
Apologies, I’ve been away.
We took the suggestion to try resolving the errors running PowerShell related to tls.
This was unsuccessful and we subsequently developed an unstable platform following our attempts.
One of our Global administrator accounts stopped working\became corrupt. Although the user is present in the SQL db, it is not present in the Intel AMT GUI.
Attempts to go back to a previous vm version also failed as the issues were compounded by a sluggish intermittent admin gui.
We are contemplating a complete rebuild. Only concern is that the gui has never worked correctly and therefore may not un-provision the test devices correctly.
tech_tc
Victor_G_Intel
Hello tech_tc,
We have not heard back from you.
Victor G.
tech_tc
Hi Victor G
Apologies, I’ve been away and returned today.
tech_tc
Kaniel
Hi tech_tc
Have you solved your issue?
It is very obvious that the issue is on your URL. The "/mdbx" is not correct to pass the parameter of the credential type.
Please try this URL
 https://my_ema_server/api/latest/amtCredentials/my_endpoint_ID/?credentialType=mebx
Kaniel
