Intel vPro® Platform
3049 Discussions
Regarding changes in behavior depending on the type of account used
SKubo
Dear IntelEMA Support Team,
If I use an AzureAD (EntraID) user account or an EMA local account for my EMA account, will there be any changes in the operation of the EMA system itself?
I think the setup method will be different, but after signing in, it will depend on the authority management within EMA, so is it correct to understand that there will be no difference in operation between AD and local accounts?
Skubo
vij1
Hello Skubo,
Greetings!
Intel EMA operates similarly whether using Azure Entra or EMA local. As you mentioned, the difference lies in user authentication.
Please refer to Section 1.3.4, "Pre-installation Instructions for Microsoft Azure AD Environments," in the Intel EMA Server Installation and Maintenance Guide:
https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/intel-ema-server-installation-and-maintenance-guide.pdf
Vijay N.
vij1
Hello Skubo,
Greetings!
I am following up on the case and wondering if I can help you with anything else. Look forward to your response.
Vijay N.
vij1
Hello Skubo,
Greetings!
I am following up on the case and wanted to check if there is anything else I can assist you with. I look forward to your response.
Vijay N.
