Intel vPro® Platform
3046 Discussions
Cannot connect to RCS behind firewall
GRile
The server hosting the RCS has its firewall enabled. I cannot connect to it using SCS Console from client PC or from the SCCM server during SCCM Add-on installation. I know there is a small section in the manual that states:
If you install the RCS on a computer that is protected by a firewall, you might receive error messages when you
try to connect to the RCS.
Solution:
You must make sure that the firewall is configured to enable the WMI to connect to the RCS. For more
information, refer to the Microsoft Developer Network:
http://msdn.microsoft.com/en-us/library/aa389286(VS.85).aspx
However this doesn't help in any way. I click the link but the page talks about using VBScript? If I disable the firewall on the RCS server I can connect so it's obviously a firewall issue, the question is which port/s do I need to open? If I capture the traffic on my PC whilst trying to connect to the RCS server I see attempts to connect on port 135 except I have tried enabling the rule "Windows management Instrumentation (WMI-In)" on the server but no luck.
Any ideas?
Graham
Dariusz_W_Intel
Graham,
you need WMI -in TCP port 135 to be opened to allow SCS console to connect - otherwise you will get Timeout error in SCS console.
Make sure that you use right RCS server IP or FQDN.
you need to enable AD user of SCS console in RCS WMI Name Space and DCOM permissions on RCS -otherwise you will get Access Denied error message in SCS Console.
the best way is to use RCSutils.exe tool with /Permissions Add command.
See SCS User Guide section called User Permissions Required to Access the RCS (3.8 for SCS 11.1)
rgds
Dariusz Wittek
Intel EMEA Biz Client Technical Sales Specialist
Dariusz_W_Intel
Graham,
rgds
Dariusz Wittek
GRile
Thanks for your reply Dariusz,
I tried this but it doesn't seem to make any difference, I still cannot connect. However, before that I managed to discover, by process of elimination, the correct ports to open on the firewall. If I opened up tcp 135 (not the built-in rule for WMI-In) and also a port range of 50000-55000 I was able to connect from my PC and from the SCCM Add-in wizard. I would still prefer to do it the correct way. Can you advise? Should I open a support ticket?
Thanks, Graham
GRile
It is working now. I needed to enable the three rules:
  • Windows Management Instrumentation (ASync-In)
  • Windows Management Instrumentation (DCOM-In)
  • Windows Management Instrumentation (WMI-In)
