Intel vPro® Platform
3052 Discussions
Cannot get a .pfx file for SCCM Out-of-Band management
I had purchased SSL Intel vPro certificate from GoDaddy.
I had downloaded SSL certificate as crt and p7b format. I had imported this certificate into ISS 7. However, I couldn't export this certificate as pfx format to use this certificate in SCCM OOB Management.
So, I had used this document http://communities.intel.com/docs/DOC-2110 http://communities.intel.com/docs/DOC-2110 to convert this certificate as pfx format.
When I run the makepfx.bat, I got an windows error Openssl.exe had stop working. BTW, I had installed SCCM on Windows Server 2008 R2. After that, I changed openssl.exe compability mode to Windows XP SP3 and run the makepfx.bat again. I had created certificate as pfx format successfully. However, When I had tried to add this pfx certificate to IIS 7, IIS 7 got an error that "not recognized
After, I had generated pfx format, I had tried to show this certificate to SCCM out of band management and got an error that the password is incorrect.
What should I do to create pfx format without having problem?
Thanks in advance.
I you attempt to load the generated pfx file into the machine's certificate store, can you do it successfully?
Why did you attempt to load this certificate into IIS?
When you attempted to load the certificate into IIS and SCCM you used the password supplied to openssl and not the password originally in the file obtained from GoDaddy right?
