Intel vPro® Platform
Intel Manageability Forum for Intel® vPro Fleet Services, EMA, AMT, SCS & Manageability Commander.
3090 Discussions
Cannot provision Intel AMT on computers
I've setup the Intel SCS Add-on for SCCM 2012 R2 SP1 CU1 and it created all these packages and task sequences to setup Intel AMT on the workstations.
I followed the guide below which was very helpful to setup the integration and to create the SCS profile.
https://sccmguru.wordpress.com/2013/12/20/integrating-configuration-manager-2012-r2-with-intel-scs-9-0-part-1/ Integrating Configuration Manager 2012 R2 with Intel SCS 9.0 – Part 1 : Introduction | SCCM GURU
I am running the following versions
  • SCS 0.0.11.35
  • SCS SCCM add-on 2.1.6.3.
The "Intel SCS: Platform Discovery" and "Intel AMT: Discovery" task sequences appears to run properly as it is returning a successful exit code.
Although when I run the "Intel AMT: Configuration" task sequence it fails. The task is running the following command line:
Configure.bat ".\AMTProfile1.xml" "SCCM2012" %_SMSTSMachineName% "%_SMSTSMP%" %_SMSTSSiteCode%
If I run it manually as administrator on a workstation I get the same error.
The ConfigAMT.log file contains some errors which I would appreciate your assistance with. A copy of the file is below. I highlighted the errors that I am getting:
2015-11-12 15:24:16: Thread:1968(INFO) : ACU Configurator , Category: HandleOutPut Source: CmdUtils.cpp : Cmd::HandleOutput Line: 79: Starting log 2015-11-12 15:24:16
2015-11-12 15:24:16: Thread:1968(DETAIL) : ACU Configurator, Category: VerifyFileSignature Source: Src\ActivatorMain.cpp : configurator::VerifyDLL Line: 102: Verifying the digital signature of ACU.dll, this operation might take up to 3 minutes...
2015-11-12 15:24:16: Thread:1968(DETAIL) : VerifyFileSignature, Category: File: ACU.dll Source: Verifier.cpp : SCS_Crypt::Verifier::Authenticate Line: 235: Entering
2015-11-12 15:24:16: Thread:1968(DETAIL) : VerifyFileSignature, Category: File: ACU.dll Source: Verifier.cpp : SCS_Crypt::Verifier::Authenticate Line: 250: Exiting
2015-11-12 15:24:16: Thread:1968(DETAIL) : ACU.dll, Category: SetCompatibilityMode Source: ACUDll.cpp : SetCompatibilityMode Line: 220: Set compatibility mode to 10.0.
2015-11-12 15:24:16: Thread:1968(INFO) : ACU Configurator, Category: -Unknown Operation- Source: Src\ActivatorMain.cpp : wmain Line: 409: workstation.comp.domain.com: Starting to configure AMT...
2015-11-12 15:24:16: Thread:1968(DETAIL) : AMT Discovery, Category: HECI Discovery Source: HECIDiscovery.cpp : CheckAMT Line: 85: Entering
2015-11-12 15:24:16: Thread:1968(DETAIL) : ACU Configurator , Category: -HECI- Source: HECIWin.cpp : HECIWin::Init Line: 191: Connected to the Intel(R) Management Engine Interface driver, version 11.0.0.1166
2015-11-12 15:24:16: Thread:1968(DETAIL) : AMT Discovery, Category: HECI Discovery Source: HECIDiscovery.cpp : FWUpdateData Line: 46: Entering
2015-11-12 15:24:17: Thread:1968(DETAIL) : AMT Discovery, Category: HECI Discovery Source: HECIDiscovery.cpp : FWUpdateData Line: 64: Exiting
2015-11-12 15:24:17: Thread:1968(INFO) : ACU Configurator , Category: AMT Mode Source: HECIDiscovery.cpp : CheckAMT Line: 418: Intel(R) AMT in PROVISIONING_MODE_ENTERPRISE
2015-11-12 15:24:17: Thread:1968(DETAIL) : AMT Discovery, Category: HECI Discovery Source: HECIDiscovery.cpp : GetPKIDNSSuffix Line: 951: Entering
2015-11-12 15:24:17: Thread:1968(DETAIL) : AMT Discovery, Category: HECI Discovery Source: HECIDiscovery.cpp : GetPKIDNSSuffix Line: 980: Exiting
2015-11-12 15:24:17: Thread:1968(DETAIL) : AMT Discovery, Category: HECI Discovery Source: HECIDiscovery.cpp : CheckAMT Line: 540: Exiting
2015-11-12 15:24:20: Thread:1968(DETAIL) : AMT Discovery, Category: HECI Discovery Source: HECIDiscovery.cpp : GetAmtFQDN Line: 1439: Entering
2015-11-12 15:24:20: Thread:1968(DETAIL) : AMT Discovery, Category: HECI Discovery Source: HECIDiscovery.cpp : GetAmtFQDN Line: 1520: Exiting
2015-11-12 15:24:20: Thread:1968(INFO) : ACU Configurator , Category: Discovery Source: HostBasedSetup.cpp : HostBasedSetup::Discovery Line: 432: Calling function Discovery...
2015-11-12 15:24:20: Thread:1968(INFO) : ACU Configurator , Category: Local System Account Source: HostBasedSetup.cpp : HostBasedSetup::GetLocalSystemAccount Line: 217: Calling function GetLocalSystemAccount over MEI...
2015-11-12 15:24:20: Thread:1968(DETAIL) : ACU Configurator , Category: -HECI- Source: HECIWin.cpp : HECIWin::Init Line: 191: Connected to the Intel(R) Management Engine Interface driver, version 11.0.0.1166
2015-11-12 15:24:20: Thread:1968(INFO) : ACU Configurator , Category: Local System Account Source: HostBasedSetup.cpp : HostBasedSetup::GetLocalSystemAccount Line: 255: Function GetLocalSystemAccount over MEI ended successfully
2015-11-12 15:24:20: Thread:1968(INFO) : ACU Configurator , Category: Discovery Source: HostBasedSetup.cpp : HostBasedSetup::Discovery Line: 479: Host Based Setup is supported
2015-11-12 15:24:20: Thread:1968(INFO) : ACU Configurator , Category: Discovery Source: HostBasedSetup.cpp : HostBasedSetup::Discovery Line: 518: Current Control Mode: 0 (Not provisioned)
2015-11-12 15:24:20: Thread:1968(INFO) : ACU Configurator , Category: Discovery Source: HostBasedSetup.cpp : HostBasedSetup::Discovery Line: 557: Allowed Control Modes: 2 (Admin) and 1 (Client)
<em style=...
